Killed the 600
+7
747JetMech
70FB
11 posters
Killed the 600 Empty Killed the 600
Post  Frank Merkl June 17th 2014, 2:23 am
Well we when out with what we thought was all are ducks in a row but , lady luck said "NO" 2nd pass we had a piston fail , tough to tell but looks like a pin boss failed and let the rod and pin run free, AND CHANGE holes ! tough to tell with all the carnage , the piston is in to small of pieces, Oh well the 632 is just about ready !!!
Killed the 600 20140616_112603_zpsqjcbka08
and we worked on it hard
Killed the 600 20140615_112306_zpsucuvtdd7
checked and rechecked
Killed the 600 20140614_173104_zpsvnsqgyib
need another A460 block anyone have one that porosity that needed 8 sleeves as a big nitrous motor needed to have sleeves put in to start !!
Killed the 600 Empty Re: Killed the 600
Post  Frank Merkl June 17th 2014, 2:27 am
that's the water jacket your seeing and I unbolted the rods as there were 2 in 1 hole , bearings were like new
Post  70FB June 17th 2014, 5:50 am
Damn I hate to see this.
70FB
70FB
Post  bbf-falcon June 17th 2014, 6:20 am
Shit happens,sometimes worse than others. Sad
Post  dfree383 June 17th 2014, 9:09 am
Shit.... it will buff out! cheers
It sucks, but it's a good reason to upgrade!
Post  Lem Evans June 17th 2014, 9:38 am
Any chance the wrist pin went 1st?
Killed the 600 Empty aries
Post  747JetMech June 17th 2014, 12:30 pm
Whose pins were you running?
747JetMech
747JetMech
Post  schmitty June 17th 2014, 1:20 pm
Yep looks just like what you described the other night.   Sad
Post  Frank Merkl June 17th 2014, 7:33 pm
the pins came with the pistons from Venoila ,their suppose to be a heavy wall tool steel pin ,172 grams , I'm thinking something happened to the pin boss and the pin did all the destruction as its shattered to shards . plumbing the 2 foggers on the intake for the 623 now
Post  Lem Evans June 17th 2014, 7:36 pm
Are they straight or tappered?
Post  Frank Merkl June 17th 2014, 7:38 pm
straight
Post  Moodyblues June 25th 2014, 5:14 pm
dang that sucks, happened to me in October, we a rod broke. Don't think I will run aluminum rods again
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
Post  Frank Merkl June 26th 2014, 9:08 am
aluminium rods are the Only thing I run unless I Win the Lotto then it will be Titanium !!
Post  Frank Merkl July 15th 2014, 1:14 am
pics of the carnage
Killed the 600 20140714_225518_zps2uszvt3k
Killed the 600 20140714_225422_zpsrtqwl1lh
Killed the 600 20140714_225415_zpswtvn1clg
Killed the 600 20140714_225406_zpsqlgs3hgl
something a sleeve and JB weld can't fix!!
Post  Frank Merkl July 15th 2014, 2:19 am
looks to me as the piston vanished and we had a connecting rod going around at 9300 rpm with no piston cleaning house !!!
Post  dfree383 July 15th 2014, 9:16 am
So what failed first? Piston? Cylinder wall? valve? Rod?
Post  Frank Merkl July 15th 2014, 1:52 pm
if I only knew!!!
Post  Frank Merkl July 16th 2014, 3:02 pm
this was  piston
Killed the 600 20140716_121246_zpswsvrzzzw
Post  dfree383 July 16th 2014, 3:21 pm
Looks to me either the piston or the cylinder wall went first.
Post  Moodyblues July 17th 2014, 9:46 pm
Looks exactly what happened to mine last October. Guy did a half track burnout and I was waiting on him to stage and felt a vibration in the shifter...........
Moodyblues
Moodyblues
Post  Frank Merkl July 17th 2014, 10:29 pm
This happened 1.06 into the 2nd pass on a fresh motor ,ie ; new rods and pistons !
Post  bbf-falcon July 17th 2014, 11:35 pm
Frank Merkl wrote:This  happened 1.06 into the 2nd pass on a fresh motor ,ie ; new rods and pistons !
Who knows,it's the life of a racer/engine builder. In the end it's all speculation. Unless the obvious shows it's ugly head.
Post  cool40 July 18th 2014, 12:35 am
dfree383 wrote:Looks to me either the piston or the cylinder wall went first.
x2...... pale
Post  DanH July 18th 2014, 5:18 am
vote for the cylinder wall failed first.
DanH
Post  Dark Horse of Apocalypse July 18th 2014, 8:14 pm
Wow that's ugly like a Wart Hog in a Prom dress.
