Now the plumbing begins
+10
Gregaust
lghting94
Dave C.
KY JELLY
14 posters
Page 1 of 2
Page 1 of 2 • 1, 2
this is tight , a pass side pump with a drivers side bear claw mount 1st stage to get over to the drivers side
URL=https://s58.photobucket.com/user/fmerkl/media/20140618_232409_zpsglw1aoq6.jpg.html][/URL]
Frank Merkl- Posts : 1524
Re: Now the plumbing begins
this is the replacement for my 600 inch that had a catastrophic failure on the weekend , this is my 632 , 4.600 bore x 4,625 stroke C460 headed motor
Can't put the pump on the other side ? That is going to be a major pain
KY JELLY- Posts : 1530
That bore and stroke is a 615 Frank.
Short stiff oil line tend to come loose.......
stroke is 4.750 , had a brain fart ,LOL
plumbed !
bungs welded in the intake ,now to plumb 2 foggers !!
Fogger 2's and annulars
better pic
I've never seen anyone so excited about breaking an engine! Keep the pics coming.
Dave C.- Posts : 1268
Bigger, faster, and stronger is the only way to go.
I just got the engine back in mine yesterday afternoon and am waiting on a few small details to finish getting it back going too.
schmitty- Posts : 4538
Get-r-done!
Dave C ,I had run that ol' 600 for 16 years !! a new motor is all ways exciting to me !! plus we should have a couple hundred more ponies to play with !!
What happened with the big "hemi" motor you built?
lghting94- Posts : 762
the 712 is still on the shelf , Charlie has the heads rubbing on them !
got juice!
the 'kids' doing it all in stainless ! because "he say's it looks better" ?! mild steel line is easier to work with !!
ps N's are 46's and 40's
As long as the C6 will handle it lol . I know it will
Gregaust- Posts : 626
the trans works great . it's the converter guy's that we have had problems with !! tell them what you have for power and a 5000 stall ends up being a 6190 stall with 15 % slip out the big end on motor!!!
Put HyTran in it that'll tighten it up some. Did you get your new converter yet?
Hytrans wont fix that, a new converter builder will though.
richter69 wrote:Hytrans wont fix that, a new converter builder will though.
Stainless is a fuggin pain. And trying to do a flaired stainless line... fogetaboutit. I guess maybe with a little heat it would have been better/easier.
Talk about some brittle stubborn metal to work with. Does look pretty when done right, but that takes a lot of patients and usually has to involve a lot of waste to make all them tiny lines right and pretty.
kim- Posts : 700
the trick with stainless is to heat it red hot with a torch then let it cool , then it flairs and bends like mild steel only a little tougher
Page 1 of 2 • 1, 2
» Plumbing an accusump
» Plumbing my nitrous kit
» plumbing a tunnel ram
» Got the new fuel tank done ... Pics added
» Moroso oil accumulator plumbing
Page 1 of 2
