Moroso oil accumulator plumbing
Moroso oil accumulator plumbing Empty Moroso oil accumulator plumbing
Post  501Cobra August 24th 2009, 9:04 pm
Hello all, new member here although I frequent 460Ford.com a lot. Posted in the introduce yourself thread now it's time to get to the important stuff.
Can I plumb my Moroso oil accumulator to the oil passage above the fuel pump mount? Just wondering as this looks to be the same passage that comes from the oil filter and would be easier than buying an adaptor to go between the filter and block.
501Cobra
Moroso oil accumulator plumbing Empty Re: Moroso oil accumulator plumbing
Post  richter69 August 24th 2009, 9:26 pm
best place IMO
Post  D. Sea August 25th 2009, 10:18 am
I have mine plumbed to the back of the block, behind the intak manifold. Either location will work.
D. Sea
D. Sea
Post  56Tbird August 25th 2009, 10:36 am
Only thing bad about going in the back of the block ,it oils the top half of the motor more .The side location above the oil filter oils it just like the pump.
56Tbird
56Tbird
Post  Lem Evans August 25th 2009, 12:43 pm
The pipe port at the front is larger also .
