Methanol carb conversion to E85
+6
jc10000rpm
Dave C.
powerstrokeace
10 posters
Methanol carb conversion to E85 Empty Methanol carb conversion to E85
Post  dfree383 June 27th 2014, 3:11 pm
I see a lot of guys converting gas carbs to E85 but has any one converted a Methanol Carb to E85?
I have an 950 one laying around and would like to use it on my buddies 10/10 build.
Is it just a matter of bleeds and jets?
Methanol carb conversion to E85 Empty Re: Methanol carb conversion to E85
Post  powerstrokeace June 28th 2014, 1:33 am
Google Mark sullens. he's the man...............
Ace
powerstrokeace
powerstrokeace
Post  dfree383 June 28th 2014, 9:01 am
powerstrokeace wrote:Google Mark sullens. he's the man...............
Ace
I'm not looking to send it out for someone to build it. I'm wanting to know if a methanol specific carb can be easily tuned for e85?
I can buy conversion kits for E85 but I'm trying to be cheap and use what I have laying around.
Post  Dave C. June 28th 2014, 9:05 am
Cheapskate.
Dave C.
Post  maverick June 28th 2014, 10:02 am
Dave C. wrote:Cheapskate.
A man after my own heart. Why buy when ya got something that will work? Cool
Post  jc10000rpm July 1st 2014, 12:33 am
the main well and main well exit channel in methanol metering blocks will be to large, also the boosters will probably need to be swapped out .
the bleeds and jets are the easy part once you get a set of metering blocks that are suited to the build.
who set-up the 950 you have ?? is it possible to post a copy of the build sheet. we can see how close you can come with the parts you have.
jc10000rpm
Post  dfree383 July 1st 2014, 1:11 am
It's a Holley list no. 80498-1
Post  dfree383 July 1st 2014, 1:13 am
Don't be hatin' ! tongue
Post  738drvr July 2nd 2014, 7:23 pm
Not hatin' but you are cheap. Me too. It's extensive enough to warrant sending it out but if you insist on doing it yourself, give a shout out to jmarkaudio over on yellow bullet. He'll get you where you need to go. Sent mine to Eric at Horsepower Innovations. Knows his stuff just like Sullens does.
You're welcome.
Post  richter69 July 2nd 2014, 8:13 pm
gonna take a different metering block for sure..........cheap bastard lol
Post  dfree383 July 2nd 2014, 8:26 pm
richter69 wrote:gonna take a different metering block for sure..........cheap bastard lol
You sure......
Specific Gravity of Gas 737.22 (15%) + Ethanol 789.20 (85) = SG of about 781.4 combined average.
Specific Gravity of Methanol is 791.30
you think just jetting and bleeds won't handle it?
Energy wise Methanol = 49% of Gas per Gallon
Ethanol E85 = 75%
So their is a big issue there........
Post  kim July 2nd 2014, 8:41 pm
Depends on the carb builder originally, and how it was set up to deal with methanol. ON the pair I bought the main wells were drilled for a second jet application, so, the ability to cut the cross section of the main feed might be a problem.
kim
Post  cool40 July 2nd 2014, 8:41 pm
I'd keep it on meth.....e85 aint all its supposed to be.IMO
Post  dfree383 July 2nd 2014, 10:06 pm
cool40 wrote:I'd keep it on meth.....e85 aint all its supposed to be.IMO
Can't buy methanol at the pump.....
Post  dfree383 July 2nd 2014, 10:10 pm
kim wrote:Depends on the carb builder originally, and how it was set up to deal with methanol.  ON the pair I bought the main wells were drilled for a second jet application, so, the ability to cut the cross section of the main feed might be a problem.
This one is an out of the box Holley methanol carb that has not been modified.
Going tovput some big gas / small alky jets in it and give it a roll. How bad could it be?
Post  hienergy557 July 2nd 2014, 10:24 pm
Have a look here!! There is a whole section on e85 conversions.
http://www.motorsportsvillage.com/forum/viewforum.php?f=21&sid=3ea4802db3ece3b976bfa81cebe0af50
hienergy557
hienergy557
Post  dfree383 July 2nd 2014, 10:40 pm
hienergy557 wrote:Have a look here!! There is a whole section on e85 conversions.
Looks like it was a good site.... Sucks that the admin shut it down.
Post  hienergy557 July 2nd 2014, 10:50 pm
It was a shame. At least the info is still there.
Also try this one. I think this one starting, was the reason MSV shut down.
The same guys frequent this one.
http://racingfuelsystems.myfunforum.org/index.php?sid=0bee1d5bcba0d9694da9933681059334
hienergy557
hienergy557
Post  jc10000rpm July 4th 2014, 9:59 am
86 to 88 main jets if using powervalves,
73 iab
26 mab
using methanol blocks idle screws wont be out very far (probably 3/4 to 1 turn)
e-85 has huge tuning window, this will have u running pretty good
dont listen to the e-85 detractors, they obviously havnt tried it yet !
jc10000rpm
Post  dfree383 July 4th 2014, 1:13 pm
Sweet that's what I was looking for, thank you.
