Giant dead spot on holly carb.
bosshoss
racinghabbit
Giant dead spot on holly carb. Empty Giant dead spot on holly carb.
Post  racinghabbit June 28th 2014, 11:39 pm
mud racing... go to take off on green and smash the pedal to the floor and the engine cuts right out for like 2 seconds then goes like a raped ape..... holley 750 with vacuum secondaries.
any idea's?
racinghabbit
racinghabbit
Giant dead spot on holly carb. Empty Re: Giant dead spot on holly carb.
Post  bosshoss June 29th 2014, 11:42 am
Lean Stumble.
Possible causes, NO or not enough accelerator pump shot.
Some fool puts a screw in the mechanism on the vac secondary linkage to force them open.
Lean idle mixture.
Low float level.
There are more..
Smile
dkp
bosshoss
bosshoss
Post  Dave C. June 29th 2014, 12:56 pm
If you are not leaving from an idle, you're using up a lot of pump shot.
Dave C.
Post  cool40 June 29th 2014, 1:17 pm
Another thought if you run a vac advance be sure its on the right port.
Post  70FB June 29th 2014, 6:12 pm
Really bad vacuum leak??
70FB
70FB
Post  460bronco June 29th 2014, 10:22 pm
Is this a new problem that started out of nowhere, or is it a result after swapping a few parts?
460bronco
460bronco
Post  racinghabbit June 29th 2014, 11:51 pm
was way to lean all the way around
racinghabbit
racinghabbit
