Street/Strip Solid Lifter Builds?
Looking for some hard running solid lifter street/strip combinations. What kind of performance are you getting out of solid lifter cams? I'm interested in performance across the board from stock heads to Boss 429's. I have a 514 assembly with ported iron Cobra Jets and port-matched Dominator Victor intake that is going in a 1964 3400 lb F-100 for street/strip antics. I calculate around 10.5:1 compression and am looking at 2" fenderwell headers. Planning on using a C6 and 3.89 gears. Hoping for high 6's in the 1/8 mile and low, low 11's in the 1/4.
fox331- Posts : 28
Re: Street/Strip Solid Lifter Builds?
10.80's with a 545 in 4160 lbs with a Lunati solid flat tappet cam. Quite a few street miles as well, and the cam's been running great for several years now.
Comp EDM lifters are your friend with a larger flat tappet cam.
Greg
Greg
Greg_P- Posts : 1009
That is a serious setup and exactly what I am looking for. Can you provide some more details?
fox331- Posts : 28
Check out this link, I have my build outlined there.
https://www.429-460.com/proven-builds-f4/street-strip-edelbrock-headed-545-video-t144.htm
Also, the new best time on the combo is a 9.95 @ 135.6 mph on a 200 shot.
Hope this helps,
Greg
Hope this helps,
Greg
» F3TE/EFI street/strip builds?
» Solid Roller for Street/Strip duty ???
» Who runs solid lifter (non-roller) cams on the street? Is this cam too big?
» Roots blower intercoolers
» Street Strip 460
» Street Strip 460
