Does a solid roller lifter with an O.D..903'' require bushing for a A460 block?
Happy 4th to the big block family!
I'm wanting to chance out the roller lifters that I have now they have not been installed but would like to exchange for Isky big block .904 EZ roller bushing ISK-3172RH904EZX.
The lifters I have now are the COMP Cams Endure-X Roller Lifters 836-16 with needle bearings.
I guess what I'm needing to know if I can run a .903” lifters without having to bushing the block? The block is new and still in the crate and is untouched.
Thank you for your input.
CHARLIEB- Posts : 145
Re: Does a solid roller lifter with an O.D..903'' require bushing for a A460 block?
NO ... for an A460 block you can simply machine the lifter bores larger for a .903" lifter to fit...
rmcomprandy wrote:NO ... for an A460 block you can simply machine the lifter bores larger for a .903" lifter to fit...
Thank you Randy for the information.
But the bushings are nice to have they are nice and easy on the lifters.
dfree383 wrote:But the bushings are nice to have they are nice and easy on the lifters.
Thanks D for the info. I think I will go with the isky ezx roller .874 . I'm hoping to have good results out of them.
» solid roller lifter
» Who runs solid lifter (non-roller) cams on the street? Is this cam too big?
» solid roller lifter recommendation
» Solid Roller Lifter Choices........
» Opinions on solid roller lifter brands
