Trick Flow Street cylinder heads
Trick Flow Street cylinder heads Empty Trick Flow Street cylinder heads
Post  BigBlockRanger November 11th 2009, 11:01 pm
n/m
Last edited by BigBlockRanger on November 18th 2009, 6:53 pm; edited 4 times in total
Trick Flow Street cylinder heads Empty Re: Trick Flow Street cylinder heads
Post  the Coug November 11th 2009, 11:29 pm
James what the heck did you do???? What Happened???
Post  IcallhimGeorge November 11th 2009, 11:46 pm
looks really close to the way mine looked last November. Charlie fixed them up for me better than new.
I had 2 hyper pistons turn themselves into croutons and a block that decided to was going to crack from the top of the deck to the bottom of the mains at about 5000rpm 175' in to the pit.
....good times Sad Sad
IcallhimGeorge
IcallhimGeorge
Post  BigBlockRanger November 12th 2009, 12:27 am
Sleeve in the block decided to break apart. It barfed pieces of sleeve back into the other 7 cylinders.
1 clean up cut and most all of the marks would be gone. I would reuse them, but I have a limited hot rod budget, so I gotta move parts to fund the purchase of other stuff from time to time. lol
