Changing gears for nitrous
gmsmkr
10SHOTS
Changing gears for nitrous Empty Changing gears for nitrous
Post  10SHOTS August 6th 2014, 11:41 pm
Swapping out the 4.10s to 3.73 gears in hopes to better my e.t. On the spray , is this the right move or wrong more , a lot of local guys told me to put in 3.55s but I feel that's to much , any of you nitrous guys had any experience with this ?
10SHOTS
10SHOTS
Changing gears for nitrous Empty Re: Changing gears for nitrous
Post  Frank Merkl August 7th 2014, 12:57 am
we started with 4.11's in the car with one kit we when to 3.89's and we picked up , 2 kits now with 3.70's and we picked up , now were playing with converters trying to get less than 5% slip going out the top end and we'll be 205- 210 mph out the big end , this is with a 33.0 -16 x 15 with 107 roll out
Post  richter69 August 7th 2014, 9:11 am
Need to know all the combo info first
Changing gears for nitrous Empty Combo
Post  10SHOTS August 7th 2014, 12:07 pm
562 CID , 4.300 stroke 4.560 bore ,tfs 325 cnc heads 14.1 compression 1150 quick fuel
Tfs intake 284-298 @.050 114 lobe sep
Power glide 1.8 straight cut , ptc converter has 1150 drop on the shift ,
29.5 10.5 tire , car is 1995 mustang 3230 with driver
Using big shot plate 275 shot ,
10SHOTS
10SHOTS
Post  richter69 August 7th 2014, 1:23 pm
3.73 or even a 3.89 imo
Post  gmsmkr August 7th 2014, 1:26 pm
I vote the 3.90 gear for a start but you will probably end up with the 3.73.
gmsmkr
gmsmkr
Post  whatbumper August 7th 2014, 1:52 pm
with a 1.80 I would do a 3.73 and loosen the converter but if it was mine I would spend the coin for a 1.58 or 1.64 and stay with the 4.10 or 4.30.
Post  10SHOTS August 7th 2014, 2:15 pm
I tried a FTI ssw93c+ set up for car for 373 gears and a 300 shot , I ran it with a 410 gear and 250 shot and the shift drop was 600 , the car was slower than with the ptc converter with the 1200 shift drop on a 250 shot
So I put the ptc back in and going try 373 gears and 275 shot , maybe that will loosing the converter up some
10SHOTS
10SHOTS
Post  nitrous.f August 9th 2014, 8:06 pm
with the 1.80 first gear I have the same problem but I think a 3.27 on my software will allow me to use a 5500 stall nos converter and on the spray 200 shot stall to 6000 and will trap at about 6300- 6400 and real easy on the crankshaft rpm! Very Happy
nitrous.f
nitrous.f
Post  whatbumper August 9th 2014, 10:44 pm
Where does your motor make power? That is pretty important. I may have missed that.
Post  richter69 August 9th 2014, 10:44 pm
Ill bet a 200 shot raises the converter a lot higher than 500 rpm, more so with tha tall ass gear.....
Post  torino501 August 10th 2014, 3:16 pm
10SHOTS wrote:562 CID , 4.300 stroke 4.560 bore ,tfs 325 cnc heads 14.1 compression 1150 quick fuel
aside from the nitrous question isn't that 1150 a little small for a 562 cid..? just asking.
torino501
Post  maverick August 10th 2014, 6:25 pm
I think so, too but I'm no nitrous guy. This weak-sister 514 likes an 1150.
Post  10SHOTS August 10th 2014, 8:48 pm
Depends on who you talk to, 1150 seems to work good , I have been told with nitrous you don't need to use a big carb , I borrowed a 1250 once and it didn't change the e.t on the spray , I did not make any changes to the 1250 because it wasn't mine
10SHOTS
10SHOTS
