Breather on a street car?
If I have a pcv valve do I need a valve cover breather as well? This is a street car.
jasonf- BBF CONTRIBUTOR
Re: Breather on a street car?
Thanks Lem and Rick. That is what I typically do but here is my problem. The faux FE windsor in my Tbucket is getting a makeover. I have some 58-60 FE valve covers on it and they have no provisions for either of a pcv valve or oil cap. I added a small hole on the passenger side for the pcv valve but I was hoping to minimize the ugliness so to speak. Not to mention the tops of the valve covers are rounded and I am worried to big of a hole may make it hard to get a good seal on a breather. I won't know till I drill a hole and try.
Holy shit Jason,that is one cool lookin Motor (sorry Lem ) I love it. I think some of the oem intakes on the old FE's had a breather tube in the intake. Cool lookin ride brother.
If you are not using a mechanical fuel pump I'd modify a fuel block off plate and add one there. You can also add it to the intake manifold. The PCV in the SEFI 5.0L engines had the PCV in the back of the intake manifold. They had a cylinder with shredded metal in it under the PCV I guess to keep the oil out. The breather hooked into the oil filler tube on the valve cover.
You could also add a tube to the side of the valve cover and run a hose to remote breather. Many just run to inside the air cleaner, but does not look like an option with those air cleaners.
Of course you could add a moon eye's breather to the valve cover side. Would be period correct look.
http://www.mooneyesusa.com/MOON-Breather-s/271.htm
466cj- Posts : 391
466cj wrote:If you are not using a mechanical fuel pump I'd modify a fuel block off plate and add one there. You can also add it to the intake manifold. The PCV in the SEFI 5.0L engines had the PCV in the back of the intake manifold. They had a cylinder with shredded metal in it under the PCV I guess to keep the oil out. The breather hooked into the oil filler tube on the valve cover.
I never thought of using the fuel pump plate. I just might try that.
bbf-falcon wrote:Holy shit Jason,that is one cool lookin Motor (sorry Lem ) I love it. I think some of the oem intakes on the old FE's had a breather tube in the intake. Cool lookin ride brother.
Thanks Rick. The early ones did indeed have a oil filler in the front of the intake. I'm going to try just the pcv valve and add a breather if need be.
jasonf wrote:bbf-falcon wrote:Holy shit Jason,that is one cool lookin Motor (sorry Lem ) I love it. I think some of the oem intakes on the old FE's had a breather tube in the intake. Cool lookin ride brother.
That will definitely work.
Looks like a windsor that you have adapted those neat valve covers too. And an air gap dual quad this is really a darn nice looking engine.
57custom- Posts : 81
57custom wrote:Looks like a windsor that you have adapted those neat valve covers too. And an air gap dual quad this is really a darn nice looking engine.
It sure is. Thanks.
» So…? K-B pistons have mutable top ring gap setting why then is there such a big difference in gap between street and tow. 4.400 x .0065=.028 street
» vc breather
» Breather setup
» Is it ok to run my motor with only one breather ?
» Bolt on oil filler cap and breather?
» vc breather
» Breather setup
