Is it ok to run my motor with only one breather ?
I'm think it should b fine but want to make sure
So I won't b able to get my vacuum pump hooked up right away cause of other issues (mandrel and rad clearance)
So will it b ok to run and race it with a line cummin out of front of one of the valve covers with baffle behind it , goin to breather tank?
The other valve cover is sealed
rocketpony- Posts : 120
Re: Is it ok to run my motor with only one breather ?
A -10 or -12 line to your 'tank' should be fine.
It's a 12anĀ
» vc breather
» Breather setup
» Breather on a street car?
» Breather set up for valve covers
» Bolt on oil filler cap and breather?
» Breather setup
