C6 Roller bearing p/n
J.Toney
What are the roller bearing part numbers needed to convert a C6 to full roller? Also, where is a good place to get C6 parts?
Re: C6 Roller bearing p/n
Theres a sticky with PN's on the other forum Frank put up years ago. Theres more than one way to do it, but his is fairly straightforward and it's pretty great he even gave that info out. Most custom builders will never share that sort of thing.
J.Toney- Posts : 398
J.Toney wrote:Theres a sticky with PN's on the other forum Frank put up years ago. Theres more than one way to do it, but his is fairly straightforward and it's pretty great he even gave that info out. Most custom builders will never share that sort of thing.
X2
Frank is very help full on the phone as well .
whitefield- Posts : 2244
Thanks, I found the sticky on the other forum with the p/n's. Question though. Is there a Timken or other brand cross for the GM 9436851 and the ford F81Z-7A166-AA?
The GM brg is a 350 pump brg. The Ford bearings are: forward planet to forward planet hub, and
Rear ring gear hub to low roller race. I can't remember which is which PN. I'll try to remember to look.
HorsinAround wrote:What are the roller bearing part numbers needed to convert a C6 to full roller? Also, where is a good place to get C6 parts?
I have 4 seasons on my trans, C6.And wanting to have it reworked this winter, What are the benefits of going full roller ,,, I have a local shop that's always done the work for me, and never had a problem,,,, Truck Pulls
samiam- Posts : 240
HorsinAround wrote:Thanks, I found the sticky on the other forum with the p/n's. Question though. Is there a Timken or other brand cross for the GM 9436851 and the ford F81Z-7A166-AA?
No they are the numbers to use .
Gregaust- Posts : 625
samiam wrote:HorsinAround wrote:What are the roller bearing part numbers needed to convert a C6 to full roller? Also, where is a good place to get C6 parts?
Stock thrusts cop a hard time and often have burn marks . The rollers take that problem away , #9 is prob the worst although they all suffer
I just had my C6 rollerized. They used 245mm GM torque converter bearings in mine. The tranny was a but of a trial and error deal but when they got it right they nailed it, it works great. I t cost me $50 for a 24 and I paid for the decals on the car - sponsorship deal. have one of Franks transbrake VB's in it and that thing is awesome. Fast, hard shifts and the brake releases like lightening. They want to inspect this winter with some runs on it to see if anything is wearing fast or odd.
BigRigTech- Posts : 763
Ok, Where can I find these bearings? I tried inputing those numbers in the autozone computer and struck out.
Any competent transmission supply house. Check local places out, you're bound to have a independent, Transtar, WIT, or even DAACO distributor somehwere. They may not use the OE PN's though. I just specify what bearing I need acccording the the exploded view of the trans in their catolog, have 'em send it to the shop. Most of thses places are retail walk-in freindly also. You just have to get your parts straight.
When I first bought these bearings, I got them straight from the dealer. Granted, it took a few days, but they were all good PN's and resonable prices. Maybe buy enough for backup or if you decide to do another down the road. Both of these a decent sources.
Or, buy cores and tear them down for the bearings!
» roller bearing c6 power difference
» Roller bearing tail shaft
» Open tracker roller bearing control arms
» KING MAIN BEARING CLEARANCE'S AT PARTING LINE..?
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
