A460 Intake gaskets for alcohol
Barney
birdracer
What brand of A460 intake gaskets are you fellows using? I need the .125" thick ones,for use with my Charlie Evans adapter plates..alcohol seems to dissolve the glue between the layers and they migrate after a time..thanks Brian
birdracer- Posts : 42
Re: A460 Intake gaskets for alcohol
I have had thd Cometics on my injected alky deal for over a year now. Work great. No movement or separation.
Had the same issue with the C460... went to cometics and so far so good. Thanks Lem.
504T- Posts : 64
For what it's worth. I am trying a set of intake gaskets for Nagy Performance Parts. They are made of a polymer and are for alcohol. They are also reusable. They sealed nicely and I only had to trim them to fit right at ends of block. They also make them for A heads and C heads. .060 thick and are priced at 74.50 a set.
514Fox87- Posts : 436
Nagy Gaskets
I have run those too - they are nice, and very re-usable. Nagy wouldn't sell direct to me and the place I was buying them from folded up - so I ended up going to the Cometic gaskets, and I am very pleased with them too.
Kurt.
Kurt.
504T- Posts : 64
I'm friends with Brad Satow at No Wear Racing. He carries them. Nowearracing.com
Lem,do you keep the .125 A and .060 C head gaskets in stock at Bf Evans?
birdracer wrote:Lem,do you keep the .125 A and .060 C head gaskets in stock at Bf Evans?
The .125" can be produced in 3-4 working days.....no stock.
where to call Lem?
Lem,where do I call to order the cometic intake gaskets?,Bf evans parts number or ask for somebody special?..top secret Direct Lem LIne?...thanks Brian
birdracer wrote:Lem,where do I call to order the cometic intake gaskets?,Bf evans parts number or ask for somebody special?..top secret Direct Lem LIne?...thanks Brian
https://www.429-460.com/t16593-bf-evans-race-parts-contact-info
Or scroll to the top of the page in the sticky's on the for sale page.
racnrick- Posts : 462
Just call for me....the phone # is in my signature on all of my post.
270-278-2376
» A460 header gaskets?
» Plastic intake gaskets?
» Intake gaskets
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» intake gaskets?
» Intake gaskets
» intake gaskets?
