off to test.... wish the Ford luck
+7
D's557BBF
kim
Dave C.
blown86hallet
11 posters
click pic for video..
blown86hallet- Posts : 1012
Re: off to test.... wish the Ford luck
No luck required that is stout...but you asked for it ...LUCK
FalconEh- Posts : 1448
I'm not sure if I'd wanna be buckled into that thing or not.
Update.
Update.
maverick- BBF CONTRIBUTOR
THis thing has WAY to much power... Never thought id say that.
Gonna test my smaller prop, try-ing to keep this thing in the water is the issue.
videos will come soon.
What Big D have to say about this?
Keep the bigger prop and throttle stop it
Limit yourself and others to only 3/4 the engines capability. Smaller prop is just going to let zing to wot easier. If anything a bigger pitch and diameter to load the engine more would probably make it easier to run at various part throttle loads.
kim- Posts : 700
Don't buckle up. Maybe you'll be thrown clear.
kim wrote:Keep the bigger prop and throttle stop it
A simple pulley change, lowering the boost fixes everything...
All and All. Just to much engine.. I knew going from Gas Carbs to Alky injection is a jump in power, but not this freaking large.
With out a capsule you want to get away from the boat.
with a capsule you buckle up.
maverick wrote:Don't buckle up. Maybe you'll be thrown clear.
When in the machine shop used to have a top alcohol hydro we played with. Stuffed right sponson on firebird lake. Capsule probably only reason driver survived. He was pretty beat up. Dave Sharp. ... I'm pretty sure there is u tube video of it.
kim- Posts : 700
Adam, you going to Belleville lake?? If so i will be out there right after work to snap some pictures of the beast!! text me back because I have a meeting in Dearborn today at 1:00
D's557BBF- Posts : 1186
D's557BBF wrote:Adam, you going to Belleville lake?? If so i will be out there right after work to snap some pictures of the beast!! text me back because I have a meeting in Dearborn today at 1:00
"D"
I took it out on Sunday, Ill be hitting the lake again during the later part of the week.. Ill give you a call, set something up..
That sounds like one bad bitch Adam
Mike R- Posts : 1381
Wild stuff there.
Dark Horse of Apocalypse- Posts : 171
screw a couple 6.7 egt sensors in it, it will give you 10 seconds to "pull over safely" then shut you down.........should do the trick..... :-)
Cant catch a fish going that fast... even if you hooked one, you'd rip the lips right off it.
Cant pull a skier.... her boobies would beat her to death and her arms would rip off. Should have put that monster in a car... to play with the rest of us crazies.
kim- Posts : 700
well...
Testing went great!! More power than i know what to do with! BLown ALky is not JOKE!
Videos suck, guess women are not that great at pushing one button and video recording???
Got the bugs worked out, next outing will be way more throttle in her!
click on the little pics for video.
Poor video or not, my pants got tight. That bitch sounds wicked
All I will say is when you put the pedal to the metal you better hang on the prop will be the only thing in the water.
I'm a boat moron. .. but don't the unlimited flat bottoms run some sort of steel tray off the back with braces like us car guys use under a wing to a bumper.. running up to the back of tje boat? Then pretty much fly the things on the back few invhes of the boat and those trays.
kim- Posts : 700
kim wrote:I'm a boat moron. .. but don't the unlimited flat bottoms run some sort of steel tray off the back with braces like us car guys use under a wing to a bumper.. running up to the back of tje boat? Then pretty much fly the things on the back few invhes of the boat and those trays.
are you talking about the Cav.. plate?
Cavation plates are the correct name for them.. and yes flat out, Flat bottom boats ride on these...
» GOOD LUCK FORD THUNDER
» Bad luck!!!
» Wish me luck !
» wish me luck
» I had a little luck so far with the bow ...
» Bad luck!!!
» Wish me luck !
» wish me luck
