I keep breaking 208f transfer cases off. any idea's
+6
kjett
557ranger
SandHillsHillbilly
racinghabbit
10 posters
I keep breaking 208f transfer cases off. any idea's Empty I keep breaking 208f transfer cases off. any idea's
Post  racinghabbit September 9th 2014, 5:27 pm
I keep breaking 208f transfer cases off. any idea's. 95 ford ranger frame and body. 79 axles and suspension. front and mid plate. rubber trans mount. NO roll cage so frame flexes a lot.  Drive shafts are not to long. pretty much when it leaves the ground it breaks off the tcase when it lands. Top broken case was from 4th of july and the second case(blue) broke aug.30th
I keep breaking 208f transfer cases off. any idea's Dirtysmudtruck_zps421d5ca7
I keep breaking 208f transfer cases off. any idea's 993384_605943796124923_1847709701_n_zps8d549b2d
I keep breaking 208f transfer cases off. any idea's IMG_2962_zps0886d820
Last edited by racinghabbit on September 9th 2014, 10:24 pm; edited 1 time in total
racinghabbit
racinghabbit
I keep breaking 208f transfer cases off. any idea's Empty Re: I keep breaking 208f transfer cases off. any idea's
Post  SandHillsHillbilly September 9th 2014, 6:15 pm
Since you are running a front and mid plate I would think you need a solid transfer case mount.
SandHillsHillbilly
SandHillsHillbilly
Post  schmitty September 9th 2014, 6:36 pm
Are you running in low side?
Post  557ranger September 9th 2014, 6:53 pm
Not enuff travel in driveshaft?
557ranger
557ranger
Post  racinghabbit September 9th 2014, 10:18 pm
Drive shaft length and travel double and triple checked...Yes i am running low range... Now to the trans mount, this i y i explained that there was no cage. if i put a solid mount on the trans and the frame twists because there is NO cage in the truck i figure that the bellhousing will break...  ? truck is fast.. Also fun fact.. this truck has been racing for 3 full years .. never broke the first 2 years...
racinghabbit
racinghabbit
Post  SandHillsHillbilly September 9th 2014, 11:30 pm
Check the CV joint twice. Check with full compression and droop then rotate a quarter turn and check again. Has pinion angles changed?
Something has changed if it went two years and never broke.
SandHillsHillbilly
SandHillsHillbilly
Post  racinghabbit September 9th 2014, 11:47 pm
after the first t case broke we shortened the front shaft 1 inch... figured that was the problem ...
Then it broke the second one 7 day's of racing later with no problems in the middle....
racinghabbit
racinghabbit
Post  FalconEh September 10th 2014, 12:47 am
Same hook? Tires or launch RPM different(motor)? What caused the t-case to become the u-joint??? Solid case upgrad req'd...when in relation to cahanging to the solid trans mount did you start breaking the t-cases..flex in the body anpossibly crossembers with a plated motor and trans, maybe the give of the mount was the stress reliever?...DNK mostly a car guy.
Post  kjett September 10th 2014, 7:56 am
with the motor/mid plates, leave the trans rubber mounted! Breaking the snout off the ford 208 is fairly common with it's longer front output than the chevy 208. You need to fab up a brace to prevent the lateral (front to rear) oscillations when the chassis, suspension, and driveline all move around. The mount should be something similar to the 205's side mount, and it should live longer.
kjett
kjett
Post  racinghabbit September 10th 2014, 12:52 pm
trans still has a rubber mount.. Never was solid. Thanks .. any more idea's would be helpful
racinghabbit
racinghabbit
Post  kjett September 10th 2014, 1:04 pm
racinghabbit wrote:trans still has a rubber mount.. Never was solid. Thanks .. any more idea's would be helpful
besides bracing the front output so it doesn't move front/rear and break like that, no...
kjett
kjett
Post  schmitty September 10th 2014, 2:03 pm
What does the planetary look like after this happens?   The 208 is notorious for grenading planetaries when abused by lots of torque.
Post  racinghabbit September 10th 2014, 5:01 pm
look fine. change the case half and go back to racing.....
racinghabbit
racinghabbit
Post  460bronco September 11th 2014, 10:23 am
What type of situation has the truck been in when the cases broke? Was it during launch? while catching air? Upon landing? just while under full throttle on a smooth surface? An answer to these may help figure out what type of force is breaking the case.
460bronco
460bronco
Post  racinghabbit September 11th 2014, 2:16 pm
breaks under full acceleration when the truck lands back on the ground when it does get a little air from a rough mud pit....
both time was the same situation. many other times it has came off the ground and not broke.
racinghabbit
racinghabbit
Post  lghting94 September 11th 2014, 3:19 pm
Do the drive shafts still have the rubber screw on seal to protect the shaft splines? If it does try removing them to allow more freedom of travel when extending and compressing the driveshaft. Also make sure it has a lot of grease on it so its not sticking. We never had any luck running the 208 transfer cases in any mud truck(fast track racing) so we quit using them after breaking several and use either the 1345 or 1356 case if in need of the very low ratio but with high horsepower/torque we run the good old 205. the 205 may be heavy(but helps with weight distribution) but they always held up for me.
lghting94
lghting94
Post  mudsow September 6th 2022, 12:12 pm
Did you ever find your problem why it was breaking
mudsow
Post  racinghabbit September 6th 2022, 3:25 pm
kinda! bump stops helped a lot on the front suspension. we cracked 1 in two years now. we run 2 trucks with 208 t case.
racinghabbit
racinghabbit
Post  68formalGT October 13th 2022, 11:44 am
Lots of high power trucks running them but they're usually on the high side with all the low range parts removed
