Pistons above the block Questions?
Pistons above the block  Questions? Empty Pistons above the block Questions?
Post  Mustang-junky September 15th 2014, 10:08 pm
I'm putting my 545 together now, the pistons are above the deck. I know this is not a big deal, I just need a bit thicker head gaskets.
My question is how do you measure how far above the deck the pistons are? Do you measure in the middle of the piston, near where the pin would be? Or at the top and bottom(intake side or exhaust side)? I can push the piston down on one side and get the opposite side of the piston to go up a bit. I'm seeing about .012" with a feeler gauge and a straight edge.
I am using 6.8" rods and Probe 10671 pistons. Piston to wall clearance was supposed to be set up using Probe's instructions.
I bought the M-6003-A429 gasket kit. The Fel-Pro 1018 head gaskets in the kit are only .041" thick. I have run SBF's at .030" quench without issue, but they were more of a street motor. Smaller bore, longer piston skirts, at a lower RPM than I plan on running with this motor.
Thanks.
Jess
Mustang-junky
Mustang-junky
Pistons above the block  Questions? Empty Re: Pistons above the block Questions?
Post  TRUKPULR September 15th 2014, 10:16 pm
Are your pistons Flat top or do they have a bump.
Check your pistons on the Pin side of the pistons .
The rocking your seeing is the piston side wall clearance.
.012 sounds like a lot I know my JE pistons call for .005
Dan
TRUKPULR
TRUKPULR
http://www.shazampulling.com
Post  Mustang-junky September 15th 2014, 11:01 pm
They are flat tops.
Jess
Mustang-junky
Mustang-junky
Post  cool40 September 15th 2014, 11:44 pm
i would check the highest point the piston could get.rock the piston and check the high side becouse it will sure rock when its running.some say quench is an important thing but i can tell you when the clearance aint enough the rod bearings become more important. Embarassed
Post  gt350hr September 16th 2014, 10:41 am
You could also cut the piston .012. There should still be plenty of deck thickness there for safe operation. I'm sure Mark would agree.
gt350hr
Post  cool40 September 16th 2014, 11:18 am
gt350hr wrote:   You could also cut the piston .012. There should still be plenty of deck thickness there for safe operation. I'm sure Mark would agree.
x2 Cool
Post  dfree383 September 16th 2014, 4:21 pm
Easier to get a set of gaskets.....
Post  cool40 September 16th 2014, 6:16 pm
dfree383 wrote:Easier to get a set of gaskets.....
unless you wanted to use standard shelf gaskets. Pistons being flat tops would be a breeze on a mill. Wink
Post  dfree383 September 16th 2014, 6:30 pm
If you have a mill and a piston vise...... Most people don't.
Post  Mustang-junky September 16th 2014, 7:09 pm
I have the shortblock assembled now. So, Cutting the pistons is out for now.
I checked the pistons across the pin area, I got about .006" out of the hole. I think I will get a set of .050" or .055" thick gaskets for now.
SCE makes a .059" thick gasket. I will probably go that way.
Jess
Mustang-junky
Mustang-junky
Post  cool40 September 16th 2014, 8:31 pm
no need for a piston vise but I can see your point.I always look at things how i would do it and having some machinery can spoil you. Cool
