welding balance weights
+11
bbfstanger
bosshoss
Rmk Boss9
Dark Horse of Apocalypse
kim
DanH
rmk57
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: welding balance weights
And to add, it's a cast crank. You probably won't be reselling it if used for racing purposes.
Curt- Posts : 2791
Paul Kane wrote:If it's correctly balanced and that's where the weight was needed then it's perfectly fine for your appplication and a complete non-issue.rmk57 wrote:I've never seen a crank balanced like this before and would some expert opinions on using this up to 6500 rpm. It's a 4.15 cast Scat crank.
Which parts (piston/rod) were used for the rest of the rotating assembly, and exactly how old is the crankshaft?
The crank was brand new.
Scat I-beam rods and SRP -28cc pistons.
I'm probably going to go ahead and use it as is. It just isn't what you expect to see when you unpack your new crankshaft.
Rmk Boss9- Posts : 19
The other weld which looks prettier than the other one and a copy of the balance card.
rmk57- Posts : 176
cranks get welded on all the time. One of the ways to repair a journal... weld, and turn back down. Original offset stuff,, add weld and move center.. Back in the stone age of this sport, China didn't cast one of every stroke out there. People remanufactured what was available.
We would weld in the Mallory slugs in the throughs..
kim- Posts : 700
To be fair i have seen a lot uglier work
Some major Swiss cheese drilling and I do recall a mopar crank once with nuts welded to it in a number of places......
I would not put that in any engine with my name on it.. "if" it comes off, it will do major damage to a lot of stuff, I won't even let a balance shop end press weight (radially).. also, that is mig welded, tungsten to cast with er70.... nope.
6t6mustang- Posts : 93
Page 2 of 2 • 1, 2
» BBF WEIGHTS?
» Race Engine Weights
» Center counter weights on crank...
» Anyone ever used this guy for doing your welding??
» spray welding ........
Page 2 of 2
