Race Engine Weights
+23
2fox
peganit2
D-CEL
Larry Williams
Kevin93
brianhaeckel
665 falcon
deliveredfast
511Fox
jts557
racnrick
27 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Race Engine Weights
Guys,
I've been doing some checking lately, with an very accurate and zeroed 1000 lb scale, of the BB Ford engines we've had going on the dyno lately. All engines were weighed without flexplate or starter, but with oil, carb and etc . In other words I've made sure that the comparisons are valid.
1. Bobby's engine. DOVE-A block, 4.442" X 4.500" = 559 CID, Milodon splayed 4 bolt main caps, P-51 heads, Victor, single 1250 QFX carb, Mezeire electric water pump. 600 lbs.
2. Mike's engine. FRPP SVO block, 4.420" X 4.300" (I think? Lem?), P-51 heads, Victor, single QFT carb, water pump. 641 lbs.
3. Todd's engine. FRPP SVO block, 4.600" X 4.500"= 598 CID, TFS A-460 heads, TFS 2 X 4 tunnel ram manifold, two QFT 1150 carbs, Mezeire electric water pump, Moroso vacuum pump, dry sump pump and lines, Peterson dry sump tank, & nitrous plumbing. 735 lbs.
4. Jeff's engine. DOVE-A block, 4.440 X 4.500"= 557 CID, short fill HardBlok, Milodon splayed 4 bolt main caps, TFS A-460 heads, TFS single four intake manifold, alum. mechanical water pump, single QFT carb. 627 lbs.
I hope this is helpful,
Charlie Evans
Charlie Evans
c.evans- BBF VENDOR SPONSOR
Re: Race Engine Weights
great info Charlie
Very interesting Charlie. What is the weight diff between a hard blocked (Bare)DoveA w/billet 4 bolt main caps. And a A460 (Bare) w/same bore?
OR What is the weight of a A460 bare block?
Looks like I should come in around 735 eh!
Curt- Posts : 2791
bbf-falcon wrote:Very interesting Charlie. What is the weight diff between a hard blocked (Bare)DoveA w/billet 4 bolt main caps. And a A460 (Bare) w/same bore?
Rick,
My old Dove block filled to the water pump holes, but with only 2 bolt mains and bored to 4.440 weighed 234.
My new A-460 block weighs 290 as it came from Lem, have not had it bored yet to see what the weight difference would be. Hopefully in a few weeks I will know the difference in weight.
racnrick- Posts : 462
I know the intake from trick flow is a heavy piece .esp when you put a hat on it.
I always wondered about weight UMMMM seems about the same as bbc
I get so sick of hearing that thing has to be heavy. And then they change a little
when you tell them you have over 500 cid in a stock block without grinding on it
jts557- Posts : 56
At last.....A guy who ain't just guessing. That's really useful info as I build my car. Thanks, Charlie.
maverick- BBF CONTRIBUTOR
Block Weights
2-bolt D9TE-AB 4.36 bore = 229 lbs
2-bolt D9TE-A2 4.39 bore = 221 lbs
2-bolt C8VE 4.36 bore = 206 lbs
2-bolt C9VE-B 4.36 bore = 210 lbs
2-bolt D1VE-A2B 4.36 bore = 223 lbs
2-bolt D1VE-A2B 4.39 bore filled = 245 lbs
2-bolt D0VE 4.36 bore = 219 lbs
2-bolt D0VE 4.440 bore = 204 lbs
4-bolt D0VE-A block = 221 lbs
A460 block, factory rough undersize bore = 302 lbs
A460 block, 4.473" bore, roller cam brgs = 265 lbs
A460 block, 4.625" bore, roller cam brgs, unfilled with caps = 255 lbs
A460 block, 4.634" bore, roller cam brgs, filled to deck with caps = 268 lbs
Nice, Nick. Much obliged.
c.evans wrote:Guys,
and,,,,,,,,,,,,,,,,,,,, no dyno numbers?????
Curt- Posts : 2791
Yes, we've got tons of dyno numbers, but that wasn't the subject of this thread. Furthermore, there are some dyno numbers that we keep to ourselves, or only share with our good customers like you.
I'll start another thread sometime soon and share some numbers.
Charlie
Charlie
You da man Uncle Charlie!
Curt- Posts : 2791
Good Ta Know
Good stuff to know.
511Fox- Posts : 251
Nobody has #s on IDT blocks?
deliveredfast- Posts : 358
deliveredfast wrote:Nobody has #s on IDT blocks?
I would think Chuck Stevens might.
Nevs- BBF CONTRIBUTOR
We should make this thread a sticky..................
richter69 wrote:We should make this thread a sticky..................
Should maybe include all the bbf blocks in if you do But good idea sir
we get some pictures posted.. I'll personally make it sticky
138- Posts : 1593
138 wrote:we get some pictures posted.. I'll personally make it sticky
HeHe,that pic w/reg. bracket is now sticky
Awsome post Charlie Thanks for taking the time
Great
This is the Greatest Website ever.
511Fox- Posts : 251
Very interesting thank you .
665 falcon- BBF CONTRIBUTOR
"2. Mike's engine. FRPP SVO block, 4.530" X 4.300" (I think? Lem?), P-51 heads, Victor, single QFT carb, water pump. 641 lbs."
If you are refering to Mike M's engine...the bore is but 4.420". So it didn't have much wt. bored out of it.
I really don't know were the 300# + wts. for the as delivered A460 blocks comes from. We got two in tuesday, both blocks including their crates and the pallet they both were straped to were less than 600#. I suspect the 290# that Rick qouted is closer to correct.
Okay Lem, thanks for the correction. I'll go back and change the bore size in the original post.
Charlie
Charlie
IDT Premier with 4.650 bore = 254#
Older A460 with 4.650 bore and filled to bottom of water pump holes = 265#
A460 block with TFS A460 heads, TFS cast tunnel ram, CSR water pump, Peterson Wide Vac pump, Danny Bee belt drive, steel oil pan, complete engine(4.65x4.15) less carbs was 655#
Weighed all of these a couple years ago on one of my chassis scales. Hope this helps
Brian
Brian
brianhaeckel- Posts : 4
» Engine shut off during race.
» Cooling a race engine
» race engine challenge
» Race Engine EFI build
» PLEASE POST PICS OF YOUR ENGINES !!
Page 1 of 3
