C6 Cooler line threads and Band question
C6 Cooler line threads and Band question Empty C6 Cooler line threads and Band question
Post  HorsinAround September 21st 2014, 8:32 pm
What is the thread for the cooler line adapters? I want to run -6 line to the coolers and am not sure what the diameter and threads are for the steel line adapters.
Band. How tight should the band be? A video I have says to tighten the bolt to 10in-lbs then loosen 1 full turn. When I do that, the band seems awful loose.
http://www.frontpagefab.com
C6 Cooler line threads and Band question Empty Re: C6 Cooler line threads and Band question
Post  whitefield September 21st 2014, 8:44 pm
HorsinAround wrote:What is the thread for the cooler line adapters? I want to run -6 line to the coolers and am not sure what the diameter and threads are for the steel line adapters.
1 turn should be good try 3/4 turn  for the band . It  depends on the year case for the cooler line  size  ! 6 an to 1/8 nps is what I use
whitefield
whitefield
Post  HorsinAround September 21st 2014, 8:56 pm
Case has an 87 stamped on it if that helps.
Post  460bronco September 21st 2014, 9:08 pm
That is 10 (ftlb) or 120 (inlb)------
460bronco
460bronco
Post  whitefield September 21st 2014, 9:29 pm
460bronco wrote:That is 10 (ftlb) or 120 (inlb)------
X2 I skipped the in lb part ^^^^^ this is correct
whitefield
whitefield
Post  HorsinAround September 22nd 2014, 8:52 am
Here are the tube adapters from the tranny. Look to be 1/8" to me. Now, NPS or npt?
C6 Cooler line threads and Band question 2014-09-22075839_zps40e7a4c3
C6 Cooler line threads and Band question 2014-09-22075918_zpsbb8c5fcf
C6 Cooler line threads and Band question Empty cooler line fittings
Post  504T September 25th 2014, 11:01 pm
Look like npt... if they are i like these: http://www.summitracing.com/parts/fra-190162
504T
504T
Post  whitefield September 25th 2014, 11:08 pm
Here is the ones I use . http://www.summitracing.com/parts/fra-481671-bl/overview/
whitefield
whitefield
Post  the Coug September 26th 2014, 6:39 am
which ever you use just remember one thing Tread tape is not your Friend when using on Aluminum, Use Teflon liquid sealer....
