Piston cleaning
DanH
72mav
Piston cleaning Empty Piston cleaning
Post  72mav October 6th 2014, 11:33 am
Hi everyone,
Whats a good blasting media that WILL NOT remove the aluminum. Just the oxidation. Damn Mice got in the box....
Thanks.
Al
72mav
72mav
Piston cleaning Empty Re: Piston cleaning
Post  DanH October 6th 2014, 11:39 am
baking soda
DanH
Post  gt350hr October 6th 2014, 11:43 am
+1 stay away from glass beading . Walnut shells would be the only other "blasting material" I would consider. Baking soda is the best.
gt350hr
Post  dfree383 October 6th 2014, 11:48 am
Scotch bright
Post  72mav October 6th 2014, 11:51 am
If Im left with corrosion scars beloww the surface, will that still be okay?
Thanks.
Al
72mav
72mav
Post  dfree383 October 6th 2014, 11:54 am
How bad is it? Post some pics.
Post  Lem Evans October 6th 2014, 11:58 am
It'd be best to tape up the ring lands and pin bores.....just blast the skirts and top.
Post  72mav October 6th 2014, 12:01 pm
Lem Evans wrote:It'd be best to tape up the ring lands and pin bores.....just blast the skirts and top.
Thanks Lem that's what I'll do. If there is a little mark left. It will just hold more oil! Laughing
Regards.
Al
72mav
72mav
Post  bbf-falcon October 6th 2014, 2:34 pm
i remember a few yrs. back Harold made rhe mistake of setting 2 of his in muratic acid for cleaning,that was a nono.i was a little concerned when i assembled it but,it turned out ok.
Post  gt350hr October 7th 2014, 10:40 am
The sides of the ring lands are not as critical as the bottom of the ring groove ( where the compression sealing is done). The lands can be rubbed on with scotchbrite and not harm them. Wash thoroughly afterwards.
gt350hr
Post  72mav October 7th 2014, 8:12 pm
Ive found that a5o/50mix of acetone and transfluid makes the best penetrant bar none. Ive done wonders with it.
72mav
72mav
