Anyone know how close the Forged L2366f piston is to cast 429 piston?
Anyone know how close the Forged L2366f piston is to cast 429 piston? Empty Anyone know how close the Forged L2366f piston is to cast 429 piston?
Post  ED468 September 3rd 2018, 9:33 am
I got a TRW book and there around 800 grams without pin i think. I guess I need to pull a stock piston off a rod and weigh. Just figured someone long time ago went through this and this a low budget cruiser engine as I got a perfect 429 crankshaft. If they are alot heavier then I find a 460 crank. Thanks..,Ed
ED468
Anyone know how close the Forged L2366f piston is to cast 429 piston? Empty Re: Anyone know how close the Forged L2366f piston is to cast 429 piston?
Post  Carl September 3rd 2018, 1:00 pm
I just happened to have a stock 1968 429 flat top piston on hand, so I threw it on the scale for you.
Piston = 809 grams
Pin = 180 grams
Rings = 62 grams
Total = 1051 grams
You can use pins of different material and/or thickness to add or subtract weight to some extent if needed.
Hope that helps.
Carl
Post  ED468 September 3rd 2018, 8:43 pm
Thats awesome Carl!. Thanks a Bunch!!
ED468
Post  Paul Kane September 4th 2018, 10:53 am
The L2366F is about 1000g with supplied pin.
If you have a block with a 10.32” deck height, then you could cut the crown down about 0.100”, thereby losing about 60g of dead weight, and then use them with a 460 crankshaft in your “budget cruiser engine.”
Note: if used with a 460 crank then small chamber heads will likely require re-cutting of the valve pocket, whereas D3VEs (10:1 c/r) should not.
