needed - stock cast piston for 68 460
customer has a 60,000 mike Lincoln, dropped something down carb, cracked a piston. C8VE 460 factory piston, .120 deep oblong dish, just need 1, holler if you can help. Thanks, Phil
pmrphil- Posts : 171
Re: needed - stock cast piston for 68 460
Still looking - anybody?
Check with Paul Kane he can probably help
Mike R- Posts : 1381
Unfortunately I have no early 460 pistons right now, only early 429 flat tops.
If the exact piston cannot be found then ya might as well press off and weigh the damaged one, cc its dish volume (or cc a good example), then find a ball park equivalent replacement that can be tuned. An engine described as such (above) won’t know the difference.
I have a box full of old ones... I will have a peek and see if any look right..
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Found one this morning - thanks to everybody that looked.
» needed dome L2443nf .060 piston
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» Good quality out of work priced cast piston.
» Stock block/tranny spacer needed for 460
» 1968 thunderjet 429 std piston needed
