527 with comp cams 34-602-9 wants 30 degrees initial timing
+8
bigblok2000ranger
QtrWarrior
DanH
dirt_worker
monkeybizness
12 posters
527 with comp cams 34-602-9 wants 30 degrees initial timing Empty 527 with comp cams 34-602-9 wants 30 degrees initial timing
Post  monkeybizness October 12th 2014, 2:43 pm
HEy guy's i need some direction on this dilemma, I had a reputable machine shop build me a 527 with procomp heads and big roller ,now i go to fire it up and it seems to want 30 degrees initial timing, I'm trying to dial it in with a vac guage ,and i can get 8.5 to 9inches but it still seems to run like a Bag of S##T any ideas, has 9.5 compression long tube headers MSD, 6ALN and holley 4150 hp series, Sad
monkeybizness
527 with comp cams 34-602-9 wants 30 degrees initial timing Empty Re: 527 with comp cams 34-602-9 wants 30 degrees initial timing
Post  dirt_worker October 12th 2014, 2:48 pm
Id verify your timing pointer is actually reading tdc.
dirt_worker
dirt_worker
Post  FalconEh October 12th 2014, 3:11 pm
How much total timing
Post  monkeybizness October 12th 2014, 3:22 pm
i'm not sure i havent had it running long enough to determine that my dist. is mallory pro and i think it has 28 built in
monkeybizness
Post  FalconEh October 12th 2014, 3:32 pm
Are you talking 58* total...I would check the firing order and the rotation of your wires vs the distributor seems simple but something is definitely wrong.
Post  maverick October 12th 2014, 5:41 pm
With the timing light connected, be sure the dist. advance is actually working.  If it's locked or stuck (acting like it's locked) then 30* wouldn't be far off.  If it's working, verify the balancer/pointer combo is correct as mentioned above.  Best way is with a piston stop.  And yeah...run through that firing order again.
You're absolutely sure you have no vacuum leaks, right?
Post  DanH October 12th 2014, 6:22 pm
monkeybizness wrote:HEy guy's i need some direction on this dilemma, I had a reputable machine shop build me a 527 with procomp heads and big roller ,now i go to fire it up and it seems to want 30 degrees initial timing, I'm trying to dial it in with a vac guage ,and i can get 8.5 to 9inches but it still seems to run like a Bag of S##T any ideas, has 9.5 compression long tube headers MSD, 6ALN and holley 4150 hp series, Sad
whats the specs of that cam? installed center line?
plus the measured compression ratio?
DanH
Post  QtrWarrior October 12th 2014, 7:16 pm
What kind of balancer ??
If it a stocker, the rubber between the hub and outer ring might have separated..
QtrWarrior
QtrWarrior
Post  bigblok2000ranger October 12th 2014, 10:00 pm
Make sure the timing light is hooked to number 1 not number 5.
Number 1 is on the opposite bank as a SBC.
bigblok2000ranger
bigblok2000ranger
Post  maverick October 13th 2014, 8:19 am
bigblok2000ranger wrote:Make sure the timing light is hooked to number 1 not number 5.
That would put him 90* away from normal timing.
Post  monkeybizness October 13th 2014, 11:57 am
Thanks guys for all the reply's i set it at 20 initial and adjusted the distributor for another 24 deg to give me total of 44 also put heavier matched color springs for the advance( MALLORY pro Mechanical )so that stoprd the scatter then adjusted it in with the carb and yes i will admit i did miss a vacuum plug(dumbass) but now she's a steady 975 rpm idle .crisp throttle response.again thanks for the suggestions
monkeybizness
Post  maverick October 13th 2014, 5:03 pm
Glad to hear you got it sorted out....but 44* still sounds like a lot of timing to me.
I'd still double check that balancer/pointer accuracy.
Post  bbf-falcon October 13th 2014, 7:13 pm
X2
Post  jasonf October 14th 2014, 1:34 pm
I can't believe it would even start at 20* initial. How does it drive now that you have it running better?
Post  monkeybizness October 14th 2014, 9:48 pm
I haven't even got it on the road and it'll snow here in the next couple of weeks so it will be next spring now, but as for starting ,it doesn't spin more than once or twice when cold(no choke) Holley 4150 pro series) and when it's warm it flashes immediately ,no drag from too much timing i dont even think it makes a quarter of a turn, AS for the balancer it is an aftermarket SFI with degrees etched into it and the pointer is mounted correctly, SO i guess i'll have to wait until spring now.IN reply to the fellow who asked it is a comp cams 34-602-9 it has a 102 intake centre line and 107 deg. lobe seperation and duration at .050 is 243 intake and 257 exhaust with .580 intake gross valve lift and .564 exhaust.has 1.5 comp energizer alum rockers. So this is my first foray into BBF., hope it works well, I used to run a Vega with a 434 but SBC are easy to build SO here i am LOL
monkeybizness
Post  69F100 October 14th 2014, 11:28 pm
monkeybizness wrote:I haven't even got it on the road and it'll snow here in the next couple of weeks so it will be next spring now, but as for starting ,it doesn't spin more than once or twice when cold(no choke) Holley 4150 pro series) and when it's warm it flashes immediately ,no drag from too much timing i dont even think it makes a quarter of a turn, AS for the balancer it is an aftermarket SFI with degrees etched into it and the pointer is mounted correctly, SO i guess i'll have to wait until spring now.IN reply to the fellow who asked it is a comp cams  34-602-9 it has a 102 intake centre line and 107 deg. lobe seperation and duration at .050 is 243 intake and 257 exhaust with .580 intake gross valve lift and .564 exhaust.has 1.5 comp energizer alum rockers. So this is my first foray into BBF., hope it works well, I used to run a Vega with a 434 but SBC are easy to build SO here i am  LOL
.has 1.5 comp energizer alum rockers the big block ford needs 1.73 rockers the 1.5 chevy rocker not going to work to good on a bbf
Post  maverick October 15th 2014, 6:20 am
I just put a crank trigger on a friend's SBF powered racecar.  Before I timed the trigger, I used the piston stop method to find TRUE top dead center.  The combination of Innovators West balancer and the timing pointer (correctly installed) were off by a hair over 3 degrees...that's all high quality parts and the timing is off.  I corrected the timing marks with timing tape on the balancer.  I don't know which part (or if both) was the culprit and I don't care...because now it's right.
While some may think that the timing marks being a little off ain't no big deal as long as the engine runs ok, it becomes a HUGE deal when using heavy doses of laughing gas.  Then you may find that REALLY ACCURATE timing is all that stands between you and heartbreak.
As for me, whether using spray or not...I wanna KNOW.  It ain't hard to check.
Post  72mav October 15th 2014, 7:06 am
Boy, 44degrees is alot for sure.Theese motors dont really need alot. 32-36 degrees tops.
72mav
72mav
Post  butterbean October 15th 2014, 10:25 am
I was going to ask about the 1.5 rockers too! maybe he wanted/needed to reduce valve lift??
butterbean
butterbean
Post  FalconEh October 15th 2014, 8:58 pm
You have all winter...pull the heads clearance the valves, and degree the camshaft too...have some 1.73 rockers on hand for this.
