Initial Timing
DanH
1Bad91
Initial Timing
Just wanted to see what most you guys are running for initial timing. And whats a good base line to start at and what would be considered too much?
1Bad91- Posts : 267
Re: Initial Timing
dynoed at 32* and runs the best n/a at 32*
Re: Initial Timing
bruno wrote:dynoed at 32* and runs the best n/a at 32*
so you locked your timing out?
1Bad91- Posts : 267
Re: Initial Timing
I'm running springs and I started it at 15* for initial
1Bad91- Posts : 267
Re: Initial Timing
1Bad91 wrote:bruno wrote:dynoed at 32* and runs the best n/a at 32*
yes sir
Re: Initial Timing
I drive my car on the street, but if I didnt i would lock it out for sure
1Bad91- Posts : 267
Re: Initial Timing
15*-16 for initial and 34-38 total what ever it likes.
res0rli9- BBF CONTRIBUTOR
Re: Initial Timing
i run mine where it doesnt start when hot , never had a timing light on it . plays a great tune when i step on it .
DanH- Posts : 1081
Re: Initial Timing
DanH wrote:i run mine where it doesnt start when hot , never had a timing light on it . plays a great tune when i step on it .
and what is your resume
Re: Initial Timing
no radio , need some entertainment. call the band knock -ping and bang . note: care less what other do , when I time my engine -- just find out what it wantsbruno wrote:DanH wrote:i run mine where it doesnt start when hot , never had a timing light on it . plays a great tune when i step on it .
DanH- Posts : 1081
Re: Initial Timing
1Bad91 wrote:I drive my car on the street, but if I didnt i would lock it out for sure
IMO,locked out timing isn't what it's bragged up to be. I run a complete MSD C/T setup,and I would just as soon have my light spring setup.
Re: Initial Timing
"IMO,locked out timing isn't what it's bragged up to be. I run a complete MSD C/T setup,and I would just as soon have my light spring setup."
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
X2
X2
Re: Initial Timing
I like my crank trigger, it goes with my external oil pump, Danny Bee belty drive, ATI balancer, green oil (and teeth), stud mount rockers, and my homemade guide plates.....................
Re: Initial Timing
Lem Evans wrote:Trigger = Roy Rogers.
and what about Dale Evans
was she yours and Charlies older sister
Re: Initial Timing
Gonna stoke the kiln and crank out another batch of guide plates thos weekend............
Re: Initial Timing
everybody tells me to lock my timing out except one good friend. If he didnt know what he was doing I probably would have by now. But street cruising dont need to be locked out and not really good for the small idling crusing
1Bad91- Posts : 267
Re: Initial Timing
ours is locked but we adjust the timing with the 7530 so I guess it's really not locked. but during the run it is locked. we only have it adjusting below 4000 for driving throught he pits and starting.
whatbumper- Posts : 3024
» initial Cam timing advise
» 527 with comp cams 34-602-9 wants 30 degrees initial timing
» Advance Cam or Not ?
» My Initial 553 build
» Initial Tune for Methanol.
