T&D base welding
+8
Dave C.
72puller
68galaxie
12 posters
T&D base welding Empty T&D base welding
Post  68galaxie October 23rd 2014, 10:15 am
I just received a T&D shaft rocker assembly.
Question is regarding welding shaft bases together.
Mild steel "strap" between the intake and exhaust bases? 1/2" X 1/8" thick mild steel material be ok?
T&D mentioned some using an allen wrench cut up and welded between bases to prevent rotation.
Ideas? a picture would be great too.
TIG or MIG?
T&D base welding IMGP5623
68galaxie
68galaxie
T&D base welding Empty Re: T&D base welding
Post  72puller October 23rd 2014, 10:43 am
I saw some that were welded together using 1/4" round rod between the ends. Looked like they were welded with a mig.
72puller
72puller
Post  FalconEh October 23rd 2014, 1:08 pm
Here is a picture of a set of mine done they are Cleveland heads with a Jesel pedestals but it show the tie bars.
Post  68galaxie October 23rd 2014, 1:54 pm
FalconEh wrote:Here is a picture of a set of mine done they are Cleveland heads with a Jesel pedestals but it show the tie bars.
Thank you for the picture.
It looks like 1/8" thick X 3/8" tie bars?
Were they mild steel? How did you weld? TIG or MIG?
68galaxie
68galaxie
Post  FalconEh October 23rd 2014, 8:21 pm
Yes, to the 1/8" x 3/8" as I recall they were TIG welded, I do not remember the type or material of rod used, I didn't weld them (not confident enough nor enough experience with a welder) they were done about 5-years ago.
Post  cool40 October 23rd 2014, 8:25 pm
Mild steel works fine, welding makes it not so mild anymore. Mine are ww's made with a one piece for the intake side.the exhaust fit close enough to just tig together.
Post  Lem Evans October 23rd 2014, 8:56 pm
16 sub plates is a sad deal .
Post  dfree383 October 23rd 2014, 10:52 pm
Don't they make a single piece stand set-up ?
Post  the Coug October 24th 2014, 6:51 am
Seems to me you pay that much for a product you shouldn't have to fix it.. to use it.. Kind of a waste of money ......
Post  Dave C. October 24th 2014, 9:44 am
I agree. Are they not stable?
Dave C.
Post  68galaxie October 24th 2014, 10:08 am
I believe there were so many machining issues (and valve tip heights) with the old A429 heads that it ends up easier to adjust each stand individually and then weld then together. The stands themselves require a small welded attachment for anti-rotation purposes.
My set up required a 0.040" spacer under the intake stands and no spacer under the exhaust stands.
Valve tip pattern looks fantastic - 0.060" wide sweep pattern.
68galaxie
68galaxie
Post  FalconEh October 24th 2014, 10:47 am
68galaxie wrote:I believe there were so many machining issues (and valve tip heights) with the old A429 heads that it ends up easier to adjust each stand individually and then weld then together. The stands themselves require a small welded attachment for anti-rotation purposes.
The minimal adjustment on the rockers, means individually adjusting the stands some may be shimmed, some may be machined. After adjusting and numbering for that and only that set of cylinder heads welding the bars in makes removal and installation easier, and adds a little insurance against one of the bolts compromising the threads in the head.
Post  gt350hr October 24th 2014, 11:22 am
The tabs are not "necessary"  on T&D rockers. I added them for convenience as my rockers ( 351C application) have to be removed to access the head bolts. The welded on locating tabs make reinstallation a snap and since every one of my stands was machined for optimum geometry, the "pairs" are always returned to the proper cylinder. The small extra effort makes installation foolproof.
gt350hr
Post  68galaxie October 24th 2014, 11:56 am
gt350hr wrote:The tabs are not "necessary"  on T&D rockers. I added them for convenience as my rockers ( 351C application) have to be removed to access the head bolts. The welded on locating tabs make reinstallation a snap and since every one of my stands was machined for optimum geometry, the "pairs" are always returned to the proper cylinder. The small extra effort makes installation foolproof.
If the locating tabs were not present what prevents the rocker from rotating? Is the 7/16" attaching bolt sufficient?
68galaxie
68galaxie
Post  Curt October 25th 2014, 10:51 am
The only consistent thing about racing parts is that they all need something just a little different on just about every application. That is why the best builders a meticulous about clearances. The convenience of shaft rockers is worth any little modification it takes to make you comfortable with them.
Post  powerstrokeace October 26th 2014, 9:54 pm
I have a set In a 557 I got from a buddy of mine. He bolted the standa right on top of the guide plates and weld them on. Then he cut the "U" part of the guide plate off.
I have a direct bolt on deal with my Jesels! No hassles at all. I just know push rod length is critical as there not a lot of adjustment in the adjuster on any shaft system
Ace
powerstrokeace
powerstrokeace
Post  psfracer November 1st 2014, 8:31 pm
dfree383 wrote:Don't they make a single piece stand set-up ?
Mine were a single piece for all of the intakes. Then the exhaust stands bolted to the one intake stand.
T&D base welding KaaseP51rockerarms
T&D base welding Kaasetopendsetup2
T&D base welding EngineDyno4webvalvelash
psfracer
psfracer
http://www.psfracer.com
