welding oil pan
welding oil pan Empty welding oil pan
Post  Tore Thu 18 Apr - 13:08
I have a seam leaking on my oil pan. If I drain the pan can this seam be mig welded with out worry of lighting up the engine? Or is there an epoxy
I can use on this?
Thanks Tore
Tore
Tore
welding oil pan Empty Re: welding oil pan
Post  rmk57 Thu 18 Apr - 13:25
Iv'e never had much luck with epoxy ( jb weld) repairs being permanent, after a couple months it starts to weep again. As far as welding on the car, not sure, for me personally, I wouldn't for the fire risk
and also porosity in the weld.
rmk57
Post  rbro460 Thu 18 Apr - 16:32
Tore wrote:I have a seam leaking on my oil pan. If I drain the pan can this seam be mig welded with out worry of lighting up the engine? Or  is there an epoxy
I can use on this?
Thanks Tore
I found a good 2, 2.5 inch crack in the bottom of my pan, good thing it was off
the motor, my Artist of a welder said he had to weld both sides, inside and outside
to make sure it doesn't leak.
It doesn't.
rbro460
rbro460
Post  69F100 Thu 18 Apr - 22:33
I would not weld it in the car if you weld it on the engine you are going to have burnt oil in the pan that not good when it lets loose and goes into the pump and bearings
Post  rmcomprandy Fri 19 Apr - 0:50
Clean it good with brake clean and brush paint it with a fiberglass resin liquid like for boat repairs.
Post  Tore Sat 20 Apr - 10:53
Tore
Tore
