C6 question
C6 question Empty C6 question
Post  slurm October 29th 2014, 11:10 am
Bought a c6 from patc and have it behind a 545 63 galaxie street driven. The first one started slipping after a couple of weeks with burnt fluid. I sent it back got the transmission last week now slips in reverse feels like it is stuck in second even when manually shifting, fluid looks fine. Could this be a valve body issue? Any suggestions would be great.
slurm
slurm
C6 question Empty Re: C6 question
Post  Frank Merkl October 29th 2014, 4:25 pm
Check the servo and see if it's stuck in the case , if not it's a vb problem
Post  slurm October 30th 2014, 1:32 pm
Thanks for the info. Got a new vb on its way.
slurm
slurm
Post  Gregaust October 31st 2014, 7:05 am
But did you check what Frank suggested ? Throwing new parts at it won't always fix it, need to check . Be also having a real good look at shifter adjustment .
Gregaust
Post  slurm October 31st 2014, 9:13 am
Yes i did servo was not stuck, however shifter adjustment i will have to check.
slurm
slurm
Post  slurm February 4th 2015, 12:03 am
update The case had a crack in it. Hits so hard bill clinton is jealous.
slurm
slurm
Post  Gregaust February 27th 2015, 5:34 am
Where was the crack out of curiosity ???? Question
Gregaust
Post  slurm March 29th 2015, 9:27 pm
They said crack was around midsection of main case. I figure it might had to do with the second gear apply servo.
slurm
slurm
