Iron Head Specialists ???
what are these ? paper weights ? what are they good for ? thxs for the help.
Re: Iron Head Specialists ???
Look like some run of the mill D3's too me.
They are better than having no car........
iron heads
need to know the cast # from pad at top by the exhaust port, outside. Will be on top left of photo. Probably a D series number. next digit indicates year as in d8 followed by two more digits. Would mean a 1968 head casting. about 74 cc's. don't sell em to the scrap man, someone needs em for budget street, but not extremely valuable.
hpwdboss1- Posts : 147
hpwdboss1 wrote:need to know the cast # from pad at top by the exhaust port, outside. Will be on top left of photo. Probably a D series number. next digit indicates year as in d8 followed by two more digits. Would mean a 1968 head casting. about 74 cc's. don't sell em to the scrap man, someone needs em for budget street, but not extremely valuable.
Rocker arm pedestal's are wrong for an early head.
<span id="sceditor-start-marker" class="sceditor-selection sceditor-ignore" style="line-height: 0; display: none;"></span><span id="sceditor-end-marker" class="sceditor-selection sceditor-ignore" style="line-height: 0; display: none;"></span>
X2
dfree383 wrote:Look like some run of the mill D3's too me.
X2
only #s i can see are a 36 on one head and a 44 on the other by the spark plug hole. On the top side on top of one of the intake port runner (on both heads)there is a badge like with a # 4L29 .
bruno wrote:only #s i can see are a 36 on one head and a 44 on the other by the spark plug hole. On the top side on top of one of the intake port runner (on both heads)there is a badge like with a # 4L29 .
1974 or 84.... L = Month of production 29 = day of production
there is an invoice , looks like they had some exhaust guides done for 235.00 .......
ive got them for zero .... ill just clean them up and wrap them im sure someone might need them
just didnt know if they would be worth taking the grinder too
they can make great power as far as factory iron heads go, the just have big chambers and getting compression needs a decent sized dome.
They are great low buck build stuff
You can cut the decks a whole bunch to get the chamber volumn down
dfree383 wrote:they can make great power as far as factory iron heads go, the just have big chambers and getting compression needs a decent sized dome.
thxs Dave
No a D would mean 70's a C8 would be a 1968hpwdboss1 wrote:need to know the cast # from pad at top by the exhaust port, outside. Will be on top left of photo. Probably a D series number. next digit indicates year as in d8 followed by two more digits. Would mean a 1968 head casting. about 74 cc's. don't sell em to the scrap man, someone needs em for budget street, but not extremely valuable.
nuclearcobra- BBF CONTRIBUTOR
Judging by the images uploaded and the date code, they look to be D3VE-A2A's that were cast on November 29, 1984. If they are fully modified and outfitted for max effort use and then used in a max effort application, they should be capable of supporting 1500-2000 hp.
Paul Kane wrote:Judging by the images uploaded and the date code, they look to be D3VE-A2A's that were cast on November 29, 1984. If they are fully modified and outfitted for max effort use and then used in a max effort application, they should be capable of supporting 1500-2000 hp.
Not N/A
So the letter C,D,E or F doesn't mean 60's , 70's , 80's and 90's ?Paul Kane wrote:Judging by the images uploaded and the date code, they look to be D3VE-A2A's that were cast on November 29, 1984. If they are fully modified and outfitted for max effort use and then used in a max effort application, they should be capable of supporting 1500-2000 hp.
Oh no, Dave, I actually did mean NA.dfree383 wrote:Not N/APaul Kane wrote:...they look to be D3VE-A2A's... If they are fully modified and outfitted for max effort use and then used in a max effort application, they should be capable of supporting 1500-2000 hp.
If you are referring to the component's engineering revision then, yes, that is what the letters mean.nuclearcobra wrote:So the letter C,D,E or F doesn't mean 60's , 70's , 80's and 90's ?Paul Kane wrote:Judging by the images uploaded and the date code, they look to be D3VE-A2A's that were cast on November 29, 1984...
» Factory production Chrysler iron hemi head vs iron cobra jet
» 521 IRON HEAD
» Cast iron RHS 460 head?
» 495 Iron Head Combo
» Need 1 iron BT head casting
» 521 IRON HEAD
