495 Iron Head Combo
+8
jm
D. Sea
RapidRuss
Old blue Racin Team
Greg_P
72mav
lghting94
12 posters
495 Iron Head Combo Empty 495 Iron Head Combo
Post  lghting94 September 3rd 2009, 9:37 am
Originally Posted by lghting94 on 460ford
Just thought I would share some info/numbers on my engine:
Dove-A 2-bolt block with Canton main girdle and windage tray system
DOOE-R Heads ported and pollished (dont know flow numbers here)
Stock crank restroked to 4 inch
GRP 6.800 aluminum Rods
Custom Ross 14.5 to 1 pistons
Custom Cam Research solid roller cam 278/286 advertised duration 772 lift 110 lobe center
Victor 4500 intake (port matched to heads)
1050 dominator
Dyno Results:
RPM TQ HP
4900 622 582
5000 620 589
5100 618 597
5200 616 607
5300 615 618
5400 615 629
5500 616 642
5600 617 655
5700 618 667
5800 619 681
5900 621 694
6000 621 707
6100 620 717
6200 620 728
6300 618 738
6400 615 747
6500 611 753
6600 606 758
6700 598 760
6800 588 758
6900 576 754
7000 562 746
lghting94
lghting94
495 Iron Head Combo Empty Re: 495 Iron Head Combo
Post  72mav September 3rd 2009, 10:38 am
Cool
Always like those steel motor builds.
72mav
72mav
Post  Greg_P September 3rd 2009, 11:32 am
Wow that's a stout piece! Very cool!!!
Twisted Evil Twisted Evil Twisted Evil Twisted Evil
Greg_P
Greg_P
Post  Old blue Racin Team September 3rd 2009, 11:34 am
Cool build man
Old blue Racin Team
Old blue Racin Team
Post  lghting94 September 3rd 2009, 2:16 pm
Thanks guys I just copied my post from the other site. This is what the motor did right after I built it in early '08. I went back earlier this year to try to get a little more but wasnt able to find much. I tryed using 1.8 rockers and it lost power, the cam was installed on a 106 intake centerline changed that to 110 with the help of a Cam Research adjustable timing system and gained approx 30 lbs of torque all the way across the board but lost about 10 - 15 horspower at peak. I also had a 1050 old style dommy on it and upgraded to the 1250 hp. Also I did a leak down test when i finished the '08 season and everthing was in good shape so i didnt re-ring or bearing the motor.
lghting94
lghting94
Post  IDT-572 September 3rd 2009, 10:02 pm
Cool Cool
Post  RapidRuss September 10th 2009, 9:39 am
Thats an Awsome Build for all Iron, especially for the cubes your running !! I like it ! Nasty Twisted Evil
RapidRuss
RapidRuss
Post  D. Sea September 10th 2009, 10:10 am
Impressive build Cool
D. Sea
D. Sea
Post  jm September 10th 2009, 2:09 pm
just shows you that IF you have a set of those iron heads...really is no need or cost wise to buy the tfs heat,p51,edels,etc, unless you are stepping up to the a-460, or c's and up. imho Neutral
jm
Post  RapidRuss September 10th 2009, 6:04 pm
D. Sea wrote:Impressive build Cool
Hey Damon !! I know there cant be water in that toilet bowl in your Avatar ! You've been drinking out of it now to many years ... Laughing I think Tracy put some Margi in there and your not sharing !! Laughing
RapidRuss
RapidRuss
Post  lghting94 September 10th 2009, 6:36 pm
JM I hate to disagree but Iron heads are ok if that is all you have or have to run them BUT in the end to get this out of them I spent alot of money actully more than aluminum scj's would've cost and I honestly believe that the tfs streets, scj aluminums, or p-51's if ported correctly can make more power than my iron cj's.
Thank you to everyone for the compliments.
lghting94
lghting94
Post  bruno September 10th 2009, 9:00 pm
wow very impressive ....... cool deal
http://WWW.CKRME.COM
Post  lghting94 September 10th 2009, 9:06 pm
thank you bruno
lghting94
lghting94
Post  schmitty September 10th 2009, 9:09 pm
lghting94 wrote:JM I hate to disagree but Iron heads are ok if that is all you have or have to run them BUT in the end to get this out of them I spent alot of money actully more than aluminum scj's would've cost and I honestly believe that the tfs streets, scj aluminums, or p-51's if ported correctly can make more power than my iron cj's.
Todd I'd agree with that 100%, the money spent on the iron stuff is worth it only if class rules mandate it. Cool
Post  geez428 October 12th 2009, 11:27 pm
any flow numbers availible for he iron heads? I will be refreshing my motor over the winter.I run iron heads presently. Budget will not permit a head swap and was wondering what could be acheived from the iron head
geez428
Post  IDT-572 October 13th 2009, 9:56 am
I am running 5.8's through the 1/8 @ 3100 lb. with a home ported set. Maybe someone will check the Wallace calculator and report what the hp would be.
Post  res0rli9 October 13th 2009, 10:04 am
IDT-572 wrote:I am running 5.8's through the 1/8 @ 3100 lb. with a home ported set. Maybe someone will check the Wallace calculator and report what the hp would be.
it says 804f/w 723r/w???
Post  lghting94 October 15th 2009, 7:06 pm
geez 428 I currently do not have flow numbers but when I pull the motor I am going to have them flowed.
lghting94
lghting94
