lil 504 Iron head
+6
badsnake306
Tony M
johndickjr
Gregaust
1Bad91
10 posters
lil 504 Iron head Empty lil 504 Iron head
Post  1Bad91 October 18th 2010, 11:38 pm
Was a home scratch build. Small roller cam 230ish/240 duration 650 lift, C9VE heads ported w/bigger valves, intake matched ported, stock crank, alum rods, Forged Dished pistons around 9:8:1 compression, stock block. First time out this past weekend after correcting a few issues from the original build. Car went from 10.60's to a whopping 10.16 @ 133mph. I'm completely shocked. I sit 3150lb with me in the car. I'm cheesing right now... Very Happy............GOD BLESS THE BIG BLOCK FORD!!!!!!!!
1Bad91
1Bad91
lil 504 Iron head Empty Re: lil 504 Iron head
Post  Gregaust October 19th 2010, 4:15 am
That's impressive Shocked Well done !!!
Gregaust
Post  johndickjr October 31st 2010, 2:18 pm
what gears ? ..tranny..converter..suspension
johndickjr
Post  1Bad91 October 31st 2010, 10:29 pm
johndickjr wrote:what gears ? ..tranny..converter..suspension
4.30......powerglide.....3000 stall......stock suspension
1Bad91
1Bad91
Post  johndickjr November 1st 2010, 12:53 pm
do you think it would be faster with a c4-c6
johndickjr
Post  Tony M November 1st 2010, 2:26 pm
Nice job ! Try that with a BBC LOL !
Tony M
Tony M
Post  1Bad91 November 1st 2010, 3:07 pm
Thunderstruck wrote:Nice job ! Try that with a BBC LOL !
LB for LB.....nothing comes close to the BBF
1Bad91
1Bad91
Post  1Bad91 November 1st 2010, 3:09 pm
johndickjr wrote:do you think it would be faster with a c4-c6
Thats a good question.....I'm fond of the PG myself. I have 3 friends including my father who all run a C4....great tranny with great results. I would say it's more fun on a all out street application but they work. I like shifting 1 time and thats the only reason why I run a powerglide.
1Bad91
1Bad91
Post  1Bad91 November 1st 2010, 3:11 pm
and this motor is running off a 4150 carb set-up. I still wonder if a 4500 carb would help this motor or if it wouldnt make a difference
1Bad91
1Bad91
Post  Tony M November 1st 2010, 3:36 pm
Id put my money on the C-4 for optimum ET.
Tony M
Tony M
Post  1Bad91 November 1st 2010, 3:43 pm
Everything would have to down right perfect.....converter...gear...etc.
1Bad91
1Bad91
Post  badsnake306 November 1st 2010, 5:35 pm
i saw your car win on pinks all out @ zmaxx. just curious if the 10 grand is going into the car lol
badsnake306
Post  richter69 November 1st 2010, 9:03 pm
You can get away with the converter, gear etc not being quite right with a 3 speed.....a glide it better be spot on. I know in a higher hp combo the glide wins hands down, in this application since your already there I'd spend the c4 money on more power and be even more ahead of the game................ Cool
Post  Tony M November 1st 2010, 10:22 pm
richter69 wrote:You can get away with the converter, gear etc not being quite right with a 3 speed.....a glide it better be spot on. I know in a higher hp combo the glide wins hands down, in this application since your already there I'd spend the c4 money on more power and be even more ahead of the game................ Cool
makes sense.
Tony M
Tony M
Post  1Bad91 November 2nd 2010, 12:02 am
badsnake306 wrote:i saw your car win on pinks all out @ zmaxx. just curious if the 10 grand is going into the car lol
You saw my car win on pinks all out? Damn!! Who was driving it??...lol. Jk...No, i just finished up some of the powder coating and ceramic coating that I wanted done. That money dont last long.....i wish I still had some of it...lol
1Bad91
1Bad91
Post  1Bad91 November 2nd 2010, 12:04 am
I'm happy with where I am now to be honest.....I think if I put a higher stall converter in the car, it will pick up. My mph tells me alot
1Bad91
1Bad91
Post  badsnake306 November 2nd 2010, 2:21 pm
with ten grand you could build a really stout engine to go with that powerglide lol
badsnake306
Post  1Bad91 November 2nd 2010, 9:30 pm
you got that right!!
1Bad91
1Bad91
Post  BOSS 429 November 2nd 2010, 10:37 pm
Thunderstruck wrote:Id put my money on the C-4 for optimum ET.
x2 for any 3 speed
Post  badsnake306 November 24th 2010, 9:33 am
i see your running aluminum rods. why did you choose those instead of a steel rod?
badsnake306
Post  1Bad91 November 24th 2010, 10:38 am
badsnake306 wrote:i see your running aluminum rods. why did you choose those instead of a steel rod?
Because when you make your rotating assembly lighter it's a lot easier on the crank. Plus lighter means faster. My bob weight is just as close to a sbc in comparison.
1Bad91
1Bad91
Post  BOSS 429 November 24th 2010, 10:38 am
alum rod = less rotating mas,engine will acc quicker this ='s better et's
Post  1Bad91 November 24th 2010, 10:41 am
SOme people have a bad experience with them but if you keep yourself disciplined on knowing you have alum rods in your motor by letting them warm before wrapping the motor......best rod you can use IMO. I drive my car on the street all the time with them. Just let the temp warm a little before leaving the house.
1Bad91
1Bad91
Post  badsnake306 November 24th 2010, 11:53 am
1Bad91 wrote:SOme people have a bad experience with them but if you keep yourself disciplined on knowing you have alum rods in your motor by letting them warm before wrapping the motor......best rod you can use IMO. I drive my car on the street all the time with them. Just let the temp warm a little before leaving the house.
what company are you running? BME? GRP?
BME rods are forged
GRP rods are cnc'd out of billet
i wanna run aluminum rods i just wanna put the right stuff in my engine
badsnake306
Post  1Bad91 November 25th 2010, 12:26 am
I run BME rods but I hear GRP are very good rods.
1Bad91
1Bad91
