lil 504 Iron head
+6
badsnake306
Tony M
johndickjr
Gregaust
1Bad91
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: lil 504 Iron head
Why does one "need" aluminum rods?
to feel special!...same reason they run shaft rockers
'65 T-BOLT- Posts : 1464
richter69 wrote:You can get away with the converter, gear etc not being quite right with a 3 speed.....a glide it better be spot on. I know in a higher hp combo the glide wins hands down, in this application since your already there I'd spend the c4 money on more power and be even more ahead of the game................
I could not agree more. The C-4 does have its place and this is probably one of them. But since you got the powerglide and you would have to put money out there to convert back to the C-4 , put it into the engine program. One thing for sure you can put some power in front of that glide. The C-4 is going to get to a point (with more power) that its going to tear the faces off the clutches, or become so violent on the leave that your gonna have a fight on your hands. JMO.
Travis
TravisRice- BBF CONTRIBUTOR
richter69 wrote:Why does one "need" aluminum rods?
I am a steel rod guy myself. Olivers all the way. The 598 that we bought off of Phillip was a aluminum rod deal, but it was a aluminum block also. We bought it that way. Hind sight I would have prefered a iron block steel rod combo. #1 you could not keep the heads sealed to the block, #2 you burned a lot of fuel with 2 carbs getting heat in the engine for the block and rods. JMO.
Travis
Phillip is now using the Oliver steel rods.TravisRice wrote:richter69 wrote:Why does one "need" aluminum rods?
Travis
Either rod is ok by me
1Bad91- Posts : 267
'65 T-BOLT wrote:to feel special!...same reason they run shaft rockers
yep the only reason i wanna run aluminum rods and have shaft rockers is to feel special.
badsnake306- Posts : 131
Page 2 of 2 • 1, 2
» Factory production Chrysler iron hemi head vs iron cobra jet
» 521 IRON HEAD
» 495 Iron Head Combo
» Iron Head Specialists ???
» Video of the iron head 472'' on a pass
» 521 IRON HEAD
Page 2 of 2
