Rocker Stand Spacers - A460 - Shaft Rockers
Rocker Stand Spacers - A460 - Shaft Rockers Empty Rocker Stand Spacers - A460 - Shaft Rockers
Post  Wheelie58 November 12th 2014, 9:35 am
Keith Fulp Motorsports now offers rocker stand spacers (shims) for Trick Flow A460 heads with shaft rockers.
The spacers are CNC laser cut from steel sheet and checked for burrs and finish. They are designed to fit the contour of the rocker mounting surface on the A460 cylinder head.
They are currently stocked in .017", .032" and .056" with other thicknesses to follow.
The spacers work with any brand of shaft rocker system and have been thoroughly tested on KFM shop engines. These are on the KFM 618, profiled in the Proven Builds section of this forum.
Priced at:
8 for $22.00
16 for $42.00
Thank you,
Keith Fulp
678-458-2033
KFMotorsports@aol.com
Rocker Stand Spacers - A460 - Shaft Rockers 94811161-22CF-4C09-A7DF-EAB3A6A6E1ED_zpsxgtpuzxe
Rocker Stand Spacers - A460 - Shaft Rockers A988C210-4114-4DCA-854D-022F9AD5A4B3_zpsdmapljh9
Rocker Stand Spacers - A460 - Shaft Rockers 005F20C4-DCF8-47BC-9147-B0A0EC72FA1A_zpsa1h3mmph
Wheelie58
Wheelie58
Rocker Stand Spacers - A460 - Shaft Rockers Empty Re: Rocker Stand Spacers - A460 - Shaft Rockers
Post  Moodyblues November 13th 2014, 3:32 pm
Nice work
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
Post  Lem Evans November 13th 2014, 4:33 pm
Keith....I think the valve guides in those heads are worn out.
Post  Wheelie58 November 13th 2014, 4:36 pm
Yeah Lem....pretty loose!
Those are "preemie" heads.
Keith
Wheelie58
Wheelie58
Post  powerstrokeace November 13th 2014, 10:35 pm
VERY COOL DEAL! I missed the set up on mine buy .030 and Jesel sent me these little round shims that do not support the whole stand. I see a set in my future for sure
Ace
powerstrokeace
powerstrokeace
Post  Wheelie58 November 14th 2014, 8:03 am
Thanks Moody and Ace
A side benefit of the unique shape...
During valve lash and inspections, if you notice a difference in orientation of the spacer, it would signal a problem before further damage occurs.
Keith
Wheelie58
Wheelie58
