C6 front pump
C6 front pump Empty C6 front pump
Post  BigBlockRanger November 20th 2014, 11:26 am
Motor is out of car, can I pull the front pump to replace the front seal and bushing without anything coming loose inside?
C6 front pump Empty Re: C6 front pump
Post  Frank Merkl November 20th 2014, 11:41 am
pull the trany out ,stand it on end on the tailshaft against your work bench , pull the pan and the vb, remove the pump bolt and with a prybar between the direct drum and pump pop the pump out , simple!!
Post  BigBlockRanger November 20th 2014, 12:06 pm
I was hoping to avoid having to pull the trans out of the car. My work space is very limited.
I guess it might be better in the long run because it's super easy to stab the engine/trans/headers as a unit.
Post  whitefield November 20th 2014, 12:06 pm
Frank Merkl wrote:pull the trany out ,stand it on end on the tailshaft against your work bench , pull the pan and the vb, remove the pump bolt and with a prybar between the direct drum and pump pop the pump out , simple!!
X2^^^^^^
whitefield
whitefield
