C6 front pump seal?
C6 front pump seal?
Need the part# for the BB C6 f/p seal that won't leek a month or two after install. It was posted on hear before but I can't find it now.
res0rli9- BBF CONTRIBUTOR
Re: C6 front pump seal?
The "black" ones I get from my supplier work excellent.
richter69 wrote:The "black" ones I get from my supplier work excellent.
Got apart # or supplier name.
might want to consider that the front pump bushing is shot and no seal is gonna seal iffen it wobbles....bobn
zbob- Posts : 271
probably not a seal problem , pump bushing to loose or converter snout out of round or converter balloned and the snouts a wobbling around
Frank Merkl- Posts : 1524
Well its in my nephew's 460 motor home and it wasn't leaking before he parked 6mths ago but when he started it up this weekend
it started leaking.
it started leaking.
res0rli9 wrote:Well its in my nephew's 460 motor home and it wasn't leaking before he parked 6mths ago but when he started it up this weekend
it started leaking.
A vehicle that sets a lot in my opinion tend to develope a lot of leaks. Put a new seal in it and check the pump bushing and converter for scaring and out of round. mostlikely just a dry seal from setting mor than drove.
whitefield- Posts : 2244
whitefield wrote:res0rli9 wrote:Well its in my nephew's 460 motor home and it wasn't leaking before he parked 6mths ago but when he started it up this weekend
it started leaking.
Yes thats what I was going to do but read on here where someone rebuilt his and his seal started leaking after a few weeks, and somebody else said that the seals now in the kits are junk and posted a part# of a seal that was like the old one's but I can' find that post, just don't want to put one in and it starts doing it again in a few months.
I use King-O-matic # 36070 , and most seals leak because of improper install ie: hammer and punch
Frank Merkl wrote:I use King-O-matic # 36070 , and most seals leak because of improper install ie: hammer and punch
X2 And I have been guilty of doing that .
Thanks guys.
» tight front pump bushing
» powerglide front seal
» Front crankshaft seal
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» C6 front pump
» C6 front pump
