Front crankshaft seal
Picked up a new Timing chain cover and noticed that it has the seal that installs from the front instead of the back like my old cover. Is one better then the other?
Re: Front crankshaft seal
Not sure if one or the other is better than the other but the one you put the seal in from the outside is alot easier if you want a seal start leaking
HorsinAround wrote:Picked up a new Timing chain cover and noticed that it has the seal that installs from the front instead of the back like my old cover. Is one better then the other?
Some early covers won't accept the seal from the outside is all.
Thanks, just checking as I thought I saw a comment on Ford Trucks about the newer style more prone to leaking.
HorsinAround wrote:Thanks, just checking as I thought I saw a comment on Ford Trucks about the newer style more prone to leaking.
I doubt that
Well I saw something to that effect in a search Saturday but can’t find it today. That is why I questioned it. I have both style covers so I can go either way.
If that is the case use the old style .HorsinAround wrote:Well I saw something to that effect in a search Saturday but can’t find it today. That is why I questioned it. I have both style covers so I can go either way.
A lot of unknowing people put the new type seal with the metal collar in the older cover from the rear so it is backwards ... that will leak for sure.
» front seal and oil sliner
» flex seal
» Part #'S
» crankshaft front snout lenght
» Boss cranksnout conversion
» flex seal
» Part #'S
