Boss cranksnout conversion
Boss cranksnout conversion Empty Boss cranksnout conversion
Post  72mav March 16th 2015, 7:33 pm
Hello everyone.
With the Boss conversion, does it still use the same front crankseal and spacer as the standard 460 crank?
Thanks.
Al
72mav
72mav
Boss cranksnout conversion Empty Re: Boss cranksnout conversion
Post  David Cole March 16th 2015, 7:38 pm
seal yes
Spacer no.
My setup uses a Scat forging that was cut down by Adney Brown. The damper is the special one made by ATI for that application. My spacer ended up being .400" thick. Keith Fulp made the spacer for me. Yours may vary due to crank, damper, etc.
Post  Lem Evans March 16th 2015, 7:50 pm
The snout dia. is the same..... it's just a case of the length being shorter @ ~ 3.500". Depending on who did the crankshaft, the key ways may vary.
Post  72mav March 16th 2015, 7:57 pm
Thanks fellas
72mav
72mav
Boss cranksnout conversion Empty seal
Post  gas6999 March 20th 2015, 7:17 am
the late model stuff does they use a standard crank, some with custom cranks[like mine] run a short shaft like a bbc,
gas6999
