351/400m conversion to 460
bb429power
zak460
im putting my 460 in my 67 f100. it has a modified in it now. i've got mounts that are supposed to work, but im not sure. it does have c6 in it, so im good there. any info would be great.
zak460- Posts : 2
Re: 351/400m conversion to 460
Well apparently my 67 f100 came with a 352 and the owner swapped it out to a 429 and it looks like it was done without any modifications. So maybe you can just drop it in there.
Join this site and you'll get a lot of help with that f100 http://www.fordification.com/
but use this site for your engine needs since it is more focused on the 429-460.
bb429power- Posts : 3129
yeah, mine was originally a 352, and i've heard that sometimes its not to bad swapping. thanks
zak460- Posts : 2
I thought you just need the correct motor mounts and frame stands (not sure if that is the correct name).
jasonf- BBF CONTRIBUTOR
zak460 wrote:im putting my 460 in my 67 f100. it has a modified in it now. i've got mounts that are supposed to work, but im not sure. it does have c6 in it, so im good there. any info would be great.
THE 400/351M TRANS WILL BOLT RIGHT UP,you will need a 460 flexplate, does it have 352/390fe frame horns? converter pilot will need to be checked to see it it fits crank, some will.
351m/400 starter bolts right on
rad necks will be in right spot
if its 2wd stock front sump will be fine
4wd you will need a rear sump
i have used a front sump in 73 to 79 4x4,but its close
-rich
BOSS 429- Posts : 2371
FE/385
You can use the FE mounts as part of the 385 installation. Position the FE mount on the 385 block. There will be one (1) hole in the mount that will align with the block. Mark the other block hole's position on the FE mount and drill it! Walleye! You have a mount! Or, fab a "solid" mount using the frame portion of your existing mount and fabbing to the block's dimensions.
Happy motoring,
Dave.
Happy motoring,
Dave.
LivermoreDave- Posts : 972
460 mounts.
These are the stock type mounts for a mid '70s truck. Probanly what was used in the one you said that looked factory.
fordman460- Posts : 100
» C or 400M oil pan
» 1979 Ford 400M engine
» Engine Swap Flywheel question/ 400M Flywheel on a 460?
» E85 Conversion
» 79 Mustang- looking to switch to 5 bolt lug pattern, what other cars will swap?
» E85 Conversion
