Carb ID help
Carb ID help Empty Carb ID help
Post  OldRedFord November 17th 2009, 12:25 am
How can I tell for sure what model Motorcraft carb I have? It was stock for a mid 70's Lincoln with a 460. The tag is missing. Since I am running the stock carb for the interm, I would like to replace the gaskets.
OldRedFord
OldRedFord
Carb ID help Empty Re: Carb ID help
Post  canzus November 17th 2009, 3:08 pm
got a picture of it?? There were a couple different carbs available...
canzus
canzus
Post  OldRedFord November 18th 2009, 10:29 pm
Pics
Carb ID help 46043510[list][*]Carb ID help 46043511
Carb ID help 46043512
i also belive I might be missing a spring for the kickdown on the carb?
OldRedFord
OldRedFord
Post  OldRedFord November 19th 2009, 12:20 pm
Do I need better pics? I belive its a Motorcraft 4350. Not sure tho. Do all I have to tell the parts guy to get a kit is that its a 4350, or do I need to know more info?
OldRedFord
OldRedFord
Post  canzus November 19th 2009, 12:41 pm
It looks like a 4350, so the kit should be for a '75 or '76 Lincoln Mk 4
canzus
canzus
Post  billandlori November 19th 2009, 12:51 pm
Hey Tim, your bench looks like mine!!!
Bill
Post  OldRedFord November 20th 2009, 1:39 am
billandlori wrote:Hey Tim, your bench looks like mine!!!
Bill
Seems like right now every horizontal surface in the garage is covered with engine parts or other parts for the F100. Laughing
Thanks guys. I wish the tag was still on the carb tho.
*EDIT* Know where I could get a extra gasket to go between the carb and intake? Intake has a spacer.
OldRedFord
OldRedFord
Post  OldRedFord November 21st 2009, 4:31 am
What would be my best options for a carb replacement with out changing the intake?
I would clean it up as far as removing the fuel bowl, but from what I read about these carbs online it sounds like they are a PITA to mess with.
OldRedFord
OldRedFord
