lets build a tunnel rammed jet boat engine
+6
DaveMcLain
gt350hr
6t6mustang
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: lets build a tunnel rammed jet boat engine
IMO I'd ditch the Eddys and pickup a pair of HP holleys
When I heard used "looks good" and Edelbrock 750 in the same post I thought the same thing. ^^^^^^^^^^^^
supervel45- Posts : 4498
i typically use holleys but that's $1500 plus additional fuel lines and linkage, eddys are simple and I have had good luck with them on other builds. mechanical secondaries would be nice tho.. it was $150 more or $1750 more...
6t6mustang- Posts : 93
Not if you go used on the Holleys. List #6109 are inline 750 double pumps with square bowls I believe. Not saying you will find used ones as cheap as the Eddy's but they are out there.
http://www.ebay.com/itm/Holley-4-Barrel-Carburetor-Carb-6109-750-CFM-Double-Pumper-4150-Tunnel-Ram-2x4-/181694788613?hash=item2a4dda7405&vxp=mtr I bet he would take a lot less, then all you have to do is find it's brother.
I would put quick fuel aluminum carbs on it, but, it might be silly to swap them out for a maybe 20 hp bump at best, when I am running logs..
Try the Eddys, I hope you get some good ones.
Page 2 of 2 • 1, 2
» Pondering a new engine build for the jet boat
» Boat engine carb convert to drag engine
» Jon Kaase SR71 Build and Dyno results that he also tested with a Tunnel Ram
» Engine Masters-Lots of Tunnel Rams This Year
» Jet Boat Build Suggestions
Page 2 of 2
