Looking into a converter
Looking into a converter Empty Looking into a converter
Post  jones December 9th 2014, 4:00 pm
Right now I assuming I will use Broader for my converter. He is suggesting a 11" with a billet front plate to go a long with the 1000hp wide ratio c6 that will have manual valve body and transbrake. I have not closed the door for another torque converter manufacturer I just don't know who has dealt with the 385 series in a 4x4. The truck will be street driven and on occasions it will be raced. My hope is to have the engine dyno'd in hopes for getting the converter right the first time.
I have tried these factory re-stalled converters and didn't have good luck. So I hop I can find one that won't build a lot of heat and hold up for the application.
Short wheel base F150, 4x4, 31" tall tires and either 3.25 or 3.05 gears with a 533cu, ported scj's with a single carb and more than likely a IS 100-300 plate.
jones
Looking into a converter Empty Re: Looking into a converter
Post  jeffgfg December 9th 2014, 4:03 pm
Give Lenny a call at Ultimate he'll set you straight.....
jeffgfg
Post  jones December 9th 2014, 4:27 pm
Would the converter guys tell me what I need to stay away from? I'm sure there are some things that should be a red flag for this combo.
jones
Post  J.Toney December 9th 2014, 7:01 pm
I've heard and seen good service with Lenny, even when an issue arises. I've used Edge, along with some other freinds, also good success. 4 different '73-79 pickup/Bronco with different flavors of BBF from 600hp 466 to a potent 598. Either vendor is a solid bet in my book.
J.Toney
J.Toney
Post  dirt_worker December 9th 2014, 10:06 pm
Ive had the e4od planet in my stuff before and imo it a TOTALLY unnecessary on anything but lowerhp/tq applications.
Realize thats not what you asked about but figured I throw that out there.r
dirt_worker
dirt_worker
Post  jones December 9th 2014, 10:58 pm
dirt_worker wrote:Ive had the e4od planet in my stuff before and imo it a TOTALLY unnecessary on anything but lowerhp/tq applications.
Thats good to know, if he hasn't started on the transmission I'll drop it off the build.
jones
