Diamond Pistons
Stangman98
Diamond Pistons
Does anyone know if Diamond makes a shelf piston for a 604 BBF? The biggest I have seen on their site is 557. If they do what is the part number?
Re: Diamond Pistons
Diamond makes everything to order.
Re: Diamond Pistons
Diamond makes "catalogue" 4.600" and 4.625" bore pistons for "A" heads, "C" heads, Profiler Heads or "THOR" heads.
For heads which are considered to be stock type you will need a "cuatom" piston from them for bores larger than 4.440" size...
Re: Diamond Pistons
Personally, I don't understand why anyone would run a 604" engine with a small "pea shooter" head on top of it.
Re: Diamond Pistons
rmcomprandy wrote:Personally, I don't understand why anyone would run a 604" engine with a small "pea shooter" head on top of it.
Street Car
Re: Diamond Pistons
I think the point is that the small head will be the limiting factor on horsepower. Yes they bolt on but you can only push so much air through the port no matter how big the engine is. You could put a little tiny head on an 820 inch engine and probably not make any more power.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Re: Diamond Pistons
Stangman98 wrote:Kasse P51, Trickflow, or Blue Thunder
With a comp. under 12.5:1
YOUR best bet is to call them
BOSS 429- Posts : 2371
Re: Diamond Pistons
Talk to Eric. He's a FORD guy.
Ace
Ace
powerstrokeace- Posts : 1496
Re: Diamond Pistons
powerstrokeace wrote:Talk to Eric. He's a FORD guy.
Ace
x2
