Estimated Hp and Tq numbers.
Estimated Hp and Tq numbers. Empty Estimated Hp and Tq numbers.
Post  BleedinBlue77 December 14th 2014, 3:04 am
Hi,
New member here and I must say I am excited to be apart of this site. I have a 79 Ford Bronco and my 400 is blowing up so i decided its time for a 460. I am using this bronco for mainly fourwheeling but want to kick some diesel ass. I have a block out of 83 f-250 with the original heads. I am going to do a mild port job, chambers polished and port match with a 750 holley carb. With roller rockers with 1:73 ratio. It will have 9.5:1 compression. A performer rpm dual plane intake. With a comp cam Hydraulic Flat Tappet, Advertised Duration 270/278, .050 duration 226/234 Lift .554/.574. I would really like to know what you guys think this motor will make. Any suggestions are greatly appreciated.
Thanks,
Luke
BleedinBlue77
Estimated Hp and Tq numbers. Empty Re: Estimated Hp and Tq numbers.
Post  DanH December 15th 2014, 3:43 am
say you want to kick diesel but. How much power do you think/want to acomplish that?
DanH
Post  BleedinBlue77 December 15th 2014, 2:55 pm
I want about 450 and in a bronco thats about 3000lbs lighter than a diesel that should be plenty.
BleedinBlue77
Post  DanH December 16th 2014, 1:31 am
BleedinBlue77 wrote:I want about 450 and in a bronco thats about 3000lbs lighter than a diesel that should be plenty.
with the right cyl.head work, you're on the way to 450hp
DanH
Post  dfree383 December 16th 2014, 12:10 pm
Add a 545 stroker kit to your list, add a bigger cam and carb, you'll have them covered in the torque department too.
Post  BleedinBlue77 December 16th 2014, 3:42 pm
Do you guys think it would be worth the money to go with super cobra jet heads or stick with the original?
BleedinBlue77
Post  dfree383 December 16th 2014, 4:56 pm
If you have the money it a worthwhile upgrade, but you will lose the stealth.
You'll need to watch the pistons too, the ford Racing SCJs have different valve locations and much smaller combustion chambers.
Post  BleedinBlue77 December 16th 2014, 6:03 pm
dfree383 wrote:If you have the money it a worthwhile upgrade, but you will lose the stealth.
Ok. They seem really nice. How much power do you think they will add. What do you mean by stealth?
I really appreciate all of your help.
BleedinBlue77
Post  dfree383 December 16th 2014, 6:08 pm
They will add 50+ hp.
Stealth is the look of it being stock and fooling the deisel guys into thinking its nothing
Post  BleedinBlue77 December 16th 2014, 6:40 pm
dfree383 wrote:They will add 50+ hp.
Thats awesome! I am not too worried about the diesel guys knowing. They think there stock diesels will be able outrun my bronco. I just don't think this will happen considering i will have more power and about the same torque but in a 3000lb lighter bronco. Would you recomend a different cam for this build?
BleedinBlue77
Post  DanH December 17th 2014, 12:14 am
OP, what is the budget? yes the heads are worth the cost. you add up the cost of the parts/labor to mod the stock iron heads?
plus the short block must be in good shape.
DanH
Post  BleedinBlue77 December 17th 2014, 12:49 am
DanH wrote:OP, what is the budget?  yes the heads are worth the cost. you add up the cost of the parts/labor to mod the stock iron heads?
Hey dan, what do think the hp and tq numbers would be with the scj heads on this build?
BleedinBlue77
Post  DanH December 17th 2014, 11:49 am
Budget + skill= HP/TQ
DanH
