what would be some good intake options
garys gt
514 pump gas motor 10.5 to 1 compression. cam is solid flat tappet 256/266 @.050 and 589/615 lift. heads are pro comp castings with manley 2.19 and 1.71 back cut valves. bowls have been smoothed out to remove casting imperfections. 2900lbs car with 4.10 gear and 28 inch tire. c6 trans with 3500 stall. car will be street/ strip mostly strip. give me some options on intakes that work best to worst. thanks
garys gt- Posts : 87
Re: what would be some good intake options
Victor with a 1050 or 1150 dominator.
with your choice in heads it really doesn't matter the heads will be the down fall, or limiter a victor will be more than you can use....
the Coug- Posts : 3055
Coug thinks your heads are junk.....
Yea heads are not that great but I got them bare with the 514 short block in a trade.the Coug wrote:with your choice in heads it really doesn't matter the heads will be the down fall, or limiter a victor will be more than you can use....
Yea there probably junk.richter69 wrote:Coug thinks your heads are junk.....
would it be beneficial to port match the heads to match the intake. Or just leave the miss match.dfree383 wrote:Victor with a 1050 or 1150 dominator.
garys gt wrote:would it be beneficial to port match the heads to match the intake. Or just leave the miss match.dfree383 wrote:Victor with a 1050 or 1150 dominator.
it won't hurt anything you do to those heads but I think with the way they flow I would get a 1050 I think an 1150 is to much...
I would do a "Victor port match" to the head and run it.
The heads CAN be decent performance heads with a LOT of work performed BUT getting a better head will have less cost attached than paying for the large amount of work to be done to those.
If you are capable to do ALL the work on those heads yourself, it just matters how much you own time is worth.
what would be the best intake gaskets to use.rmcomprandy wrote:I would do a "Victor port match" to the head and run it.
Personally ... Fel-Pro #1231S-3 are the gaskets I use and recommend.
What type car is it.. what are you wanting to ET... How well do you want the car to perform on street Idle, sound, comfort..garys gt wrote:514 pump gas motor 10.5 to 1 compression. cam is solid flat tappet 256/266 @.050 and 589/615 lift. heads are pro comp castings with manley 2.19 and 1.71 back cut valves. bowls have been smoothed out to remove casting imperfections. 2900lbs car with 4.10 gear and 28 inch tire. c6 trans with 3500 stall. car will be street/ strip mostly strip. give me some options on intakes that work best to worst. thanks
quick 52- Posts : 612
it's a fox body coupe with near no interior and probably using race seat so not much comfort. Think it should have a nice sound. The stall should absorb enough of the cam to drive on the road a little. Don't know how fast the car will be. Just a guess would be 6.50 in the 1/8 mile. What would you think.quick 52 wrote:What type car is it.. what are you wanting to ET... How well do you want the car to perform on street Idle, sound, comfort..garys gt wrote:514 pump gas motor 10.5 to 1 compression. cam is solid flat tappet 256/266 @.050 and 589/615 lift. heads are pro comp castings with manley 2.19 and 1.71 back cut valves. bowls have been smoothed out to remove casting imperfections. 2900lbs car with 4.10 gear and 28 inch tire. c6 trans with 3500 stall. car will be street/ strip mostly strip. give me some options on intakes that work best to worst. thanks
6.50 is around 10 teens in the 1/4... That pretty stout for a mild build... There is always nitrous
IMO mid to upper 10's if you're on your game low 11's if you're off.
Low 10's will need more air and compression.
If your motor puts out 500 hp and I believe it will and probably more... and your suspension is working at lease 1.48 60'.. You should be mid 10's put 150 HP. of nitrous 9.80 to 10.0
quick 52 wrote:If your motor puts out 500 hp and I believe it will and probably more... and your suspension is working at lease 1.48 60'.. You should be mid 10's put 150 HP. of nitrous 9.80 to 10.0
How do you see This? I knew a guy that has a 524 Pro Comp headed engine with a bigger Roller cam and a victor and 1050 in a tube Chassis car, only run 10.7 with those heads and He had a lot more compression....
Those heads must be terrible then. I don't have any experience with them but would think they would perform as well as a iron head. And if a 514 can make 500hp and will 60' it should run mid 10's in a 2900 pound carthe Coug wrote:quick 52 wrote:If your motor puts out 500 hp and I believe it will and probably more... and your suspension is working at lease 1.48 60'.. You should be mid 10's put 150 HP. of nitrous 9.80 to 10.0
Some people can sink the titanic, others can get a canoe across the Atlantic. Two identical builds in two different garages will often come out with very different results. Some people can tune carbs, adjust timing, others can buy an engine and expect to race. Many racers have little to no clue to what's happening under the hood, or along the suspension, they are just damn good at stab and steer. Others are fantastic with all the bits and widgets that make the car work..... they suck at stab and steer... then there are the really rare few, that know both. They win division and national championships.
kim- Posts : 700
your engine combo with a port matched Victor and a 1050 Dommy and @ 2900 lbs it should run 6.70/6.80's in the 1/8th and 10.50/10.60's in the 1/4 but with a little more compression and a roller cam it could go 1/2 second quicker in the 1/4 JMO good luck
butterbean- Posts : 676
[quote="kim"]
Some people can sink the titanic, others can get a canoe across the Atlantic. Two identical builds in two different garages will often come out with very different results. Some people can tune carbs, adjust timing, others can buy an engine and expect to race. Many racers have little to no clue to what's happening under the hood, or along the suspension, they are just damn good at stab and steer. Others are fantastic with all the bits and widgets that make the car work..... they suck at stab and I'll say that your right on with that statement... When I did DW there were guys rebuilding there car's on the side of the road an others giving up over nothing
Hey if you guys think they are so good you should each go buy a set and save all that money cuz you are such good engine builders... I bet ya'll could get way more hp than anyone ever has.... you seem to know so much about it...
the Coug wrote:Hey if you guys think they are so good you should each go buy a set and save all that money cuz you are such good engine builders... I bet ya'll could get way more hp than anyone ever has.... you seem to know so much about it...
I know enough about them to spend my money in better heads.... But hey the guy has them and wants to use them..... No skin off anyone here.
Not saying I'm a engine builder or tuner... Did say if he can make 500hp with those heads and have a good 60' in a 2900lbs car it should run mid 10's and hose will wake it up to 9.80 to 10.0the Coug wrote:Hey if you guys think they are so good you should each go buy a set and save all that money cuz you are such good engine builders... I bet ya'll could get way more hp than anyone ever has.... you seem to know so much about it...
» Intake options for d0ve headed 429
» offy port o sonic 460 intake in good shape un ported trade for parts or sell
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» Race parts, good prices
» 95 460 EFI rebuild options
