Racepak Info
Racepak Info
Racepak info - who can offer info on setups, and applications for a Street/Strip setup with some pro's and cons with integration of other electronics (7531 etc.) under streetable conditions, vs RPM activated switches for things like NOS stages. Never really been much for delay boxes but times are changing and maybe this old school racer needs to get with the program...Thanks
FalconEh- Posts : 1448
Re: Racepak Info
just buy a sportsman race pak system,it does everything but egts.if you want those you need a v300
-Rich
-Rich
BOSS 429- Posts : 2372
Re: Racepak Info
Attention: Racepak Sportsman Data Logger Customers
With Sportsman data logger customers asking for just a few more channels, the Racepak engineering staff recently completed updates, providing the ability to add additional V-Net channels to the Sportsman.
Available NOW, existing and new Sportsman data logger customers can add up to 12 additional channels, increasing the total V-Net sensor inputs from 6 to 18, while retaining the 8 pre-programmed EGT channels.
Upgrades are available in sets of 2 channels or 4 channels, and can be mixed and matched up to 12 total new channels.
Adding channel capabilities is an easy phone call to the Racepak office, as upgrades are accomplished through emailed software. Of course, new Sportsman orders can be upgraded before leaving the Racepak factory.
Re: Racepak Info
Call Racepak and discuss your needs with Eric Lowe.
He has been my rep there and knows their products well.
They don't actually integrate with programmable ignitions, other than being viewed on the same computer screen if you add the Power Grid.
However, you can use the RacePak data to set up a retard strategy for your programmable MSD.
Eric is the man.
Keith Fulp
Eric is the man.
Keith Fulp
Re: Racepak Info
Re: Racepak Info
Racepak Dashes are really cool. I want to put one in my truck, and get rid of all the analog guages, do they make one that's just a guage panel, I don't need all the special sensors for my basic bracket combo, I just want one that will have all the basic readings, like RPM, Oil Press, Water Temp, Volts, Vacuum, etc.
514F-1- Posts : 242
Re: Racepak Info
514F-1 wrote:Racepak Dashes are really cool. I want to put one in my truck, and get rid of all the analog guages, do they make one that's just a guage panel, I don't need all the special sensors for my basic bracket combo, I just want one that will have all the basic readings, like RPM, Oil Press, Water Temp, Volts, Vacuum, etc.
Just go to the RacePak web site. http://www.racepak.com/Components/UDX.php
There are 3 UDX models. One requires a RacePak and two models do not.
Keith
Re: Racepak Info
Wheelie58 wrote:514F-1 wrote:Racepak Dashes are really cool. I want to put one in my truck, and get rid of all the analog guages, do they make one that's just a guage panel, I don't need all the special sensors for my basic bracket combo, I just want one that will have all the basic readings, like RPM, Oil Press, Water Temp, Volts, Vacuum, etc.
Keith
Thanks for the heads up Keith. The price is less than I thought, can't buy a nice full set of guages for that..
514F-1- Posts : 242
Re: Racepak Info
Oops I forgot to logout... Thanks for the info Guys
Re: Racepak Info
They have what you want, it's called the UDX Street Rod. I plan on putting one in my Econoline tow truck.
I see they finally have a module for the Replay and GoPro cameras,
UDXSR Features:
· Tachometer.
· Speedometer (requires sender)
· Odometer and Trip Odometer
· Water Temperature
· Oil Pressure
· Oil Temperature (transmission or engine)
· Fuel Level (requires sender)
· Indicator lights for the following items:
o Low oil pressure warning
o High oil temperature warning
o High water temperature warning
o Low battery voltage warning
o Parking brake indicator
o Turn signal indicator
o High beam indicator
· External warning light output.
· External shift light output.
· Relay output for automatic cooling fan control.
· V-Net port for expansion of up to 32 additional channels. (requires PC software)
· Minimum and Maximum value recall.
· Electro luminescent(EL) back light.
Re: Racepak Info
BOSS 429 wrote:just buy a sportsman race pak system,it does everything but egts.if you want those you need a v300
-Rich
Sportsman does do egt's.
Here's the info I got from Greg Kelly. This was in 2011, before you could add channels.
The chanel count goes like this: (Sportsman)
1 Engine RPM
2 Shaft RPM
3 Volts
4 Accel G meter
5 Lateral G meter
6 Record button
7 12 volt event
8-13. User V-net
14-21 reserved for EGT
You can not add channels
You can not change any definitions. In the 6 available you can plug in fuel pressure, water temp, O2, boost, nitrous pressure etc (up to 6 total).
Digital vs v-net I don’t think is relevant. For instance if you wanted to get front wheel speed it would be a digital signal but still takes one of the 6 V-net channels to record it.
hienergy557- Posts : 179
» help data loggers
» race data digital dash
» Help need info.............
» Racepak Sportsman?
» Racepak drive shaft rpm sensor
