need help building motor
+11
QtrWarrior
DFI429
kim
557 Torino man
fordhighboy
15 posters
Page 1 of 2
Page 1 of 2 • 1, 2
have stock 460 and finally blew, so going to rebuild it and its going in a mud truck on 2.5 ton axles turning 50-60" tractor tires. defiantly buying stroker kit for it and p51 heads. what stroker kit should i buy and opinions on what cam and everything to use? going to be my first engine build so any advice is greatly appreciated. wanting to get to 700hp-800hp and same range in torque too and be reliable and last for few years
fordhighboy- Posts : 4
my old Quadzilla is for sale
hi, if you have not built the truck yet you can get my 74 ford with everything already done,,,7 years and never got beat in a mud bogg after I put the 57" Accurat tires on it ,,I was running a 557 also ,,,single NP-205 ,and 2 1/2 ton axels...the horsepower and the Accurat tires are the combination,,,......DO NOT GET A SET OF 54 BOGGERS, NO TRACTION AND WORST THING I EVER DID WAS GET A SET,,,they have just half of the lugs heighth that the 44 boggers do,,,they will not move enough mudd...you are doing right with the 557 ,,,very awesome motor and will make all the power you need,,,we just used a eagle rotating assbly on our first one ..get Bullet cams to make you the cam ,,,they ground me a very good one I still have the cam big roller cam if you are interested,you can have it for $ 150 might bring you some luck,,lol,,,also use as small as a stall as you can get by with...in that deep mudd you want the tires spinning as fast as possible with Quadzilla we was running 150 - 200 foot holes in 6 sec to 8 secondscall me if you need anything I will be glad to help you 417-342-2067 cell,,,my shop is 417-847-8040,,,just ask for joe
557 Torino man- Posts : 2
Re: need help building motor
Already got truck built. Got 57" v treads on it right now. What kind of stall should I get? Do think 557 stroker kit would be better for mud bogging then more of a mellow stroker kit like 514? Where it still has lot of low end torque and high end torque where 557 has insane amount of low end but not as good top end? Where did you get your stroker kit from? And what cam and rockers you use? I'm just wanting to shoot for 700-800hp and about same in torque
fordhighboy wrote:Already got truck built. Got 57" v treads on it right now. What kind of stall should I get? Do think 557 stroker kit would be better for mud bogging then more of a mellow stroker kit like 514? Where it still has lot of low end torque and high end torque where 557 has insane amount of low end but not as good top end? Where did you get your stroker kit from? And what cam and rockers you use? I'm just wanting to shoot for 700-800hp and about same in torque
a guy without a clue, how do you figure a 514 will have more torque in any range than a 557? the 557 will eat that 514 in every power range and torque range you can think of.... the 4.5 inch stroke crank will always build more torque than a 4.15 inch stroke crank
the Coug- Posts : 3055
the Coug wrote:fordhighboy wrote:Already got truck built. Got 57" v treads on it right now. What kind of stall should I get? Do think 557 stroker kit would be better for mud bogging then more of a mellow stroker kit like 514? Where it still has lot of low end torque and high end torque where 557 has insane amount of low end but not as good top end? Where did you get your stroker kit from? And what cam and rockers you use? I'm just wanting to shoot for 700-800hp and about same in torque
you should use a slightly less sharp stick when you poke someone.... not everyone professes to know all... He asked for help.... splain.. versus bash.
kim- Posts : 700
kim wrote:the Coug wrote:fordhighboy wrote:Already got truck built. Got 57" v treads on it right now. What kind of stall should I get? Do think 557 stroker kit would be better for mud bogging then more of a mellow stroker kit like 514? Where it still has lot of low end torque and high end torque where 557 has insane amount of low end but not as good top end? Where did you get your stroker kit from? And what cam and rockers you use? I'm just wanting to shoot for 700-800hp and about same in torque
I think that hitting the SEARCH Button is not that hard probably 100s of builds and reasons and I am not a doctor so I am fresh out of Patients...
when that's the prominent attitude of the "click", the sight is destined to die. Instead of inviting new posts, new members, and repeating sometimes simple information, there will be 10 people occasionally posting "what happened" until Bruno just quits paying the bill.
kim- Posts : 700
kim wrote:when that's the prominent attitude of the "click", the sight is destined to die. Instead of inviting new posts, new members, and repeating sometimes simple information, there will be 10 people occasionally posting "what happened" until Bruno just quits paying the bill.
Did you really just refer to this site as a clique???
The Coug may be coarse, but he's got the right media.. People like this guy whose first post consists of uninformed gibberish without any obvious homework beforehand and then asking
"How do I build the perfect motor with MY ideas listed??!?!?!?"
Gets farking old after a while.
I don't frequent the 'other' site too often. Between the constant newbs who seem to refuse to do for themselves, and the amateur experts who talk (type) too much..
This site has the best in the BBF world around on a regular basis.. Basic engine 101 questions going unanswered won't bury it I for one aren't about to stop visiting, or promoting the vast wealth of knowledge available here.
Me either... I hit the site several times a day. I reference people to check the site if they are contemplating a big block ford. I agree, there are many people here with a whole lot of knowledge. Guess I'm getting kinder and more gentle in my old age. If I don't know anything, or, if I don't feel like telling someone about the best oil filter, or greatest exhaust, or whatever newb question is posted, I simply don't respond.
Yes, if you've been a major contributor to the information of successful builds with a certain head, or for a certain combination, and its the 1000 time the question is asked, I understand it gets to be a pain to retype the story again. That's why the successful build section is here.
Just saying a polite recommendation to check the build section would provide the poster with a hell of a shopping list and starting point. IF he then had follow questions, he'd at least have a road map to go down and check, compare, ask about specifics.
There is most assuredly a clique within this forum.
kim- Posts : 700
What do you have for parts now? Are there any rules you need to follow? A good DOVE head 557 would get you where you are headed, but a decent set of TFS Streets or SCJ's would make it easier. There is no replacement for displacement, and price is comparable for cranks, so get the big stroke. If it's in your budget, Callie's has a 4.75" forged crank available. Good luck and keep an open mind to suggestions offered here, lots of good guys who have done this a lot.fordhighboy wrote:Already got truck built. Got 57" v treads on it right now. What kind of stall should I get? Do think 557 stroker kit would be better for mud bogging then more of a mellow stroker kit like 514? Where it still has lot of low end torque and high end torque where 557 has insane amount of low end but not as good top end? Where did you get your stroker kit from? And what cam and rockers you use? I'm just wanting to shoot for 700-800hp and about same in torque
schmitty- Posts : 4538
Nicely done, Schmitty. Informative without insults or condescension.
maverick- BBF CONTRIBUTOR
fordhighboy wrote:have stock 460 and finally blew, so going to rebuild it and its going in a mud truck on 2.5 ton axles turning 50-60" tractor tires. defiantly buying stroker kit for it and p51 heads. what stroker kit should i buy and opinions on what cam and everything to use? going to be my first engine build so any advice is greatly appreciated. wanting to get to 700hp-800hp and same range in torque too and be reliable and last for few years
It'd matter a lot if the engine will be pump gas or race gas. Which way are you headed?
[quote="maverick"]Nicely done, Schmitty. Informative without insults or condescension.[/quot
X2
X2
X 2
WE didn't ask you for patience....Just not to be as big an A**...........
QtrWarrior- Posts : 2703
nope no rules that i need to follow this is just a big monster mud bogging truck. will be ran on pump gas. im wanting to be around atleast 800ish havnt ordered any parts been asking for opinions on what company to order stroker kit from and what kind of head/cam and everything would be good choice to get what i want. ive got 5k in bank right now and will have lot more when get tax check so trying to compile a parts list and start ordering. ive read up and am going to go with 557 stroker kit just dont know what company as ive heard both bad and good from companys like scat/eagle etc and was told to go with p51 heads?
The pump gas deal will definitely make this a lot harder. 800 is doable, but the tune is going to be critical. What about going with a turbo engine?
http://www.460ford.com/forum/showpost.php?p=635044&postcount=27
windsor- Posts : 1167
X2 on a hard loaded, heat making mudbogger. From what I imagine, WOT, for 30-60 seconds or more with alot of load. Along the same lines as a boat. That'll wanna make heat, and detonate if the wrong fuel. I might think different in a street/drag app with less wieght and more speed. Personally, I dig E85.schmitty wrote:The pump gas deal will definitely make this a lot harder. 800 is doable, but the tune is going to be critical. What about going with a turbo engine?
J.Toney- Posts : 398
The forged Lunati & Scat crankshafts are the ones I prefer.
J.Toney wrote:X2 on a hard loaded, heat making mudbogger. From what I imagine, WOT, for 30-60 seconds or more with alot of load. Along the same lines as a boat. That'll wanna make heat, and detonate if the wrong fuel. I might think different in a street/drag app with less wieght and more speed. Personally, I dig E85.schmitty wrote:The pump gas deal will definitely make this a lot harder. 800 is doable, but the tune is going to be critical. What about going with a turbo engine?
Yep, if he's where E85 is available a 13.5/1 545"-557" deal will make some shit happen
Lem Evans wrote:J.Toney wrote:X2 on a hard loaded, heat making mudbogger. From what I imagine, WOT, for 30-60 seconds or more with alot of load. Along the same lines as a boat. That'll wanna make heat, and detonate if the wrong fuel. I might think different in a street/drag app with less wieght and more speed. Personally, I dig E85.schmitty wrote:The pump gas deal will definitely make this a lot harder. 800 is doable, but the tune is going to be critical. What about going with a turbo engine?
i can run 110 octane just rather not pay $7 gallon lol. and yes we have E85 here in indiana
Know anyone local with experience with it? Go get some insight on E85 and see what they think, or read up a bit on it. There are lots of facts and rumors from what I've experienced. As far as subsidy $ and price at the pump in the future, who knows?
Thats funny, it was $.89 a 2 weeks ago here in W.Michigan. Still, if its available and resonable for cost, doesn't hurt to learn about it.
J.Toney wrote:Thats funny, it was $.89 a 2 weeks ago here in W.Michigan. Still, if its available and resonable for cost, doesn't hurt to learn about it.
It's a little cheaper in kentucky than In. ....always has been about the price of preminium unleaded here.
Page 1 of 2 • 1, 2
» Building and all out drag motor
» Building a street driven motor. need Idea's
» Building a c-4 for a 408
» Building a ´71 SCJ now.
» Building A Mean 460...?
Page 1 of 2
