Blue thunder B heads?
chuck
The car I bought has a 557 with blue thunder heads. Any body run these with success? I have a 250hp in the fogger, weather will not cooperate. Ive tried to go to the track for 2weeks. What kind of ET have you seen with these heads?
chuck- Posts : 414
Re: Blue thunder B heads?
Blue Thunder has manufactured several heads of different mods.
standard exhaust port
standard exhaust port but raised .650"
Chevrolet Big Block exhaust flange
and,
each of those heads were all produced with 72, 82 or 100 cc combustion chambers.
Then they changed the intake ports and made all of them in 74 and 90cc combustion chambers.
They are all good heads.
and,
mine work very well...
click on pic for nice sounding blower video... We all love this sound!!
blown86hallet- Posts : 1012
Mine don't sound quite that good, but max effort on the heads, 400cfm intake, and a max effort intake manifold, does alright with 18-1 compression and a monster long cam.... Itll let a 525 cu in engine walk out to 9200 RPM and pull an easy 920hp NA.. a little spray, twin systems over 500... and its about 1520 or so.......
kim- Posts : 700
kim wrote:Mine don't sound quite that good, but max effort on the heads, 400cfm intake, and a max effort intake manifold, does alright with 18-1 compression and a monster long cam.... Itll let a 525 cu in engine walk out to 9200 RPM and pull an easy 920hp NA.. a little spray, twin systems over 500... and its about 1520 or so.......
400 cfm on the intake? Who did your port work?
I'm at 3125lbs with me in the car. Going to work my way up to a 36 jet on the fogger. I made around 840hp on Brian Mathews dyno. Curious how nitrous friendly they are?
chuck- Posts : 414
Champion cylinder head claims they got 400 out of the heads on my motor.blown86hallet wrote:kim wrote:Mine don't sound quite that good, but max effort on the heads, 400cfm intake, and a max effort intake manifold, does alright with 18-1 compression and a monster long cam.... Itll let a 525 cu in engine walk out to 9200 RPM and pull an easy 920hp NA.. a little spray, twin systems over 500... and its about 1520 or so.......
chuck- Posts : 414
Heads were done here in Tucson
Cant remember the guys name. He wad huge into 351c stuff. Most everything else in town is all chevy. He was in several of the rags from the 90s for some high end 347 stuff. The intake Chris Straub found for me. The port match to the heads was fingernail smooth.
kim- Posts : 700
If Champion done the heads than they are done rite, they are just about the best in the state of Florida.
butterbean- Posts : 676
That's good to know...... thanks!butterbean wrote:If Champion done the heads than they are done rite, they are just about the best in the state of Florida.
chuck- Posts : 414
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» Blue Thunder Heads
» Heads, blue thunder
» Are these blue thunder heads?
» Blue thunder Heads
