Carbon Graphite Doors for 64 fairlanes
http://www.botelerracing.com/BOTELER_RACING/Ford_Thunderbolt.html
747JetMech- Posts : 272
Update
He sent me a email concerning the CG doors. Should be ready this summer. Has anyone used the fiberglass stuff from these guys?
Thx
Thx
Re: Carbon Graphite Doors for 64 fairlanes
Just curious, what is this 'carbon graphite' you're referring to? Besides never hearing of it in body panels, your link doesn't mention it either.. It does mention carbon fiber, which is well known.
Then you mention fiberglass..
Sorry
I still refer to it as Carbon Graphite. Old term from sheet metal class 20 years ago. Used it in a preprag form for repairs, etc.
Carbon (fiber)
From Wikipedia, the free encyclopedia
Jump to: navigation, search
This article is about loose or woven carbon filament. For the rigid composite material made from carbon fiber used in aerospace and other applications, see Carbon fiber reinforced polymer.
Fabric made of woven carbon filaments
Carbon fiber, alternatively graphite fiber or CF,[citation needed] is a material consisting of fibers about 5–10 μm in diameter and composed mostly of carbon atoms.
To produce carbon fiber, the carbon atoms are bonded together in crystals that are more or less aligned parallel to the long axis of the fiber as the crystal alignment gives the fiber high strength-to-volume ratio (making it strong for its size). Several thousand carbon fibers are bundled together to form a tow, which may be used by itself or woven into a fabric.
The properties of carbon fibers, such as high stiffness, high tensile strength, low weight, high chemical resistance, high temperature tolerance and low thermal expansion, make them very popular in aerospace, civil engineering, military, and motorsports, along with other competition sports. However, they are relatively expensive when compared to similar fibers, such as glass fibers or plastic fibers.
Carbon fibers are usually combined with other materials to form a composite. When combined with a plastic resin and wound or molded it forms carbon fiber reinforced polymer (often referred to as carbon fiber) which has a very high strength-to-weight ratio, and is extremely rigid although somewhat brittle. However, carbon fibers are also composited with other materials, such as with graphite to form carbon-carbon composites, which have a very high heat tolerance
Carbon (fiber)
fiberglass
They are selling fiberglass doors, etc now. They will be offering CARBON FIBER doors this summer...
Ferstansi?
Ferstansi?
747JetMech wrote:I still refer to it as Carbon Graphite. Old term from sheet metal class 20 years ago.
LOL, you're giving away your age
Doug Rahn wrote:747JetMech wrote:I still refer to it as Carbon Graphite. Old term from sheet metal class 20 years ago.
Lol.. got it
Anyone used fiberglass components from this company?
Has anyone used fiberglass components from this company? How is the quality?
512Fairlane- Posts : 694
Update...
Good morning
You contacted us about getting carbon fiber doors for a 64 Ford Thunderbolt and I wanted to bring you up to date. They will be available in early spring of 2015 March/April. Also, the hood will be available too!
Approx. cost $1185.00 - $1245.00 for doors and the 5" Tear Drop hood will be approx. $695.00
If still interested please contact us.
Dwight
Boteler Racing Operations
PO Box 642
Westminster, MD 21158-0642
p 410.876.6851
f 410.876.6851
c 410.236.3715
Dwight
PO Box 642
p 410.876.6851
f 410.876.6851
c 410.236.3715
Not worth the money, effort, or time for such a small weight loss lmo. I only lost 100# after doors, front fenders , and all the glass.
Yup
I agree Rick. I wonder how much weight you save from glass vs carbon
» Graphite based coating dry lubricant?
» OT---Fairlane question
» DID IDT CLOSE THERE DOORS?
» landrum leaf springs and lakewood trac.bars for comets and fairlanes
» fox body doors
» fox body doors
