Graphite based coating dry lubricant?
went with a buddy yesturday to a engine shop and as i was looking around a engine caught my eye the lifter valley looked great and the block was just sitting with nothing covering it i said how u get that to look that good and not rust and he said i have my blocks burned and use graphite in a spray can in lifter valley and bottom of block it will stay that way with no rust and want hurt the engine when it built so before i do this i would like some opinions thanks.
bigjohn2007- BBF CONTRIBUTOR
Re: Graphite based coating dry lubricant?
It does work very good, but I still put a bag over my blocks to keep the dust from settling on/in them...
ThndrChkn- Posts : 2216
Spray graphite kinda works for corrosion control.. but it WILL rust in time. I'd be more worried about the bores/lifter bores/mains though. We use that stuff in various forms (spray, dip, brush) at work. For long term storage there's also soft-film corrosion preventative compound (spray) - it's like a spray wax that can be cleaned off rather quickly with a hot pressure wash. Use that too at work for equipment.
i will be putting something over my engine to but i also like the look it make to the lifter valley as long as it want hurt when i put it together.
Just don't get any in the lifter bores.. Even though it's a 'lube', it will take up clearances quick and cause sticking/galling.
that what i was thinking what u use to clean your lifter bores before installing the lifters would those brushs for summit that u can put on a drill work fine?
ThndrChkn wrote:It does work very good, but I still put a bag over my blocks to keep the dust from settling on/in them...
Me too. I sprayed my fresh .080 block w/wd-40 and trash bagged it w/breathing holes in the bottom 4 yrs ago.Checked it a few weeks ago to show a friend the block mods and the bores and lifter galley looked great.
bigjohn2007 wrote:that what i was thinking what u use to clean your lifter bores before installing the lifters would those brushs for summit that u can put on a drill work fine?
If you're talking about cleaning up the graphite, acetone or alcohol kinda works for what we use (it's tough stuff). Beside that, for the lifter bores I would want to stay as non-abrasive as possible.. dissolve what you can, and beyond that you're getting into taking away material (machining).
» Carbon Graphite Doors for 64 fairlanes
» a/f based on length of run
» It may be Chrysler based but damn its still bad azzed!
» Big Hp looking at 1200hp And up, on conv head 460 based block
» Is Header coating worth the expense
