Air cleaner
Gregaust
jones
Air cleaner Empty Air cleaner
Post  jones January 10th 2015, 11:38 pm
I need to find a good larger air cleaner for my 521 engine, it will need to fit a 4500 Holley style carburetor. I'm sure there is some out there that makes a good base a lid that will fit a large air filter. Besides those cheap china stamp steel stuff.
Your help would be appreciated!
jones
Air cleaner Empty Re: Air cleaner
Post  Doug Rahn January 11th 2015, 7:11 am
Moroso makes the largest one I have seen. Aluminum base and top, element is 16" in diameter and 4" tall. Part #65920.
Post  Gregaust January 12th 2015, 5:49 am
This one is good http://www.knfilters.com/search/product.aspx?prod=60-1640
Gregaust
Post  kjett January 12th 2015, 8:35 am
Check www.speedwaymotors.com out. I know it's a dirt track place, but their brand of the reusable filters look exactly like the k&n's but are half the price. or if you want to pay full price, they have the k&n's as well.
kjett
kjett
Post  jones January 12th 2015, 10:10 am
Thanks guys, I'll do some looking.
jones
Post  jones January 12th 2015, 10:14 am
Gregaust wrote:This one is good    http://www.knfilters.com/search/product.aspx?prod=60-1640
I have seen these but wanted something nicer and a little more filter.
jones
Post  jones January 12th 2015, 10:24 am
What do you think about this style?
http://www.advancedaircleanersystems.com/applications-custom.htm
One option could be to do a high water type intake setup.
jones
Post  jones January 12th 2015, 11:01 am
This one looks interesting, not really my thing but it would be nice to show off the carb.
http://www.r2cperformance.com/products/product.aspx?ProductId=286
Air cleaner P1010175%20b
jones
Post  Curt January 12th 2015, 12:53 pm
I have this one. It has a bell that has been cut down on the sides to fit into a tray. It doesn't affect the sealing. I also have a chrome top for it as well.
Air cleaner 100_4644
Air cleaner 100_4645
Post  jones January 12th 2015, 1:09 pm
Curt,what diameter filter is that?
I think I am going to go with the 18" diameter housing with a 4" tall filter. Unless I decide to go with some type of snorkel setup or if I can find a larger filter. The 18" specs say it will flow 2,600 cfm and that doesn't sound like enough.
I do like the clear top and base. I'm probably going to use a QuickFuel Black Diamond 1250 or 1150 QFX carburetor. Hate to cover that pretty gem under a plain jane air filter housing.
I would have thought there would be more air filters available for a dominator carb. I guess most sanction bodies that run off road require the smaller carbs.
jones
Post  Curt January 12th 2015, 1:25 pm
jones wrote:Curt,what diameter filter is that?
14x6
The flow numbers are much higher without the oil. Since this was a dragster filter only, I never oiled it. Just used it to keep out the bigger particles and rocks. I ran it on a 598 at 7,700 rpm without any reduction in performance. Now I have duals and use the corvette filter.
Air cleaner Newbuild37
Post  jones January 12th 2015, 3:20 pm
This all might change..
If the setup sits close to the hood I might throw a cowl hood on and do something different.
jones
Post  rmcomprandy January 12th 2015, 4:55 pm
www.universalspinners.com
Post  maverick January 12th 2015, 6:45 pm
Don't be afraid of restriction if you're using a good gauze type filter (like K&N). I have one on my racecar (it's a 4" x 14" deal on an 1150 Dominator) and have run alternating passes with and without the air cleaner numerous times...and saw no discernable difference on my timeslips.
Post  jones January 12th 2015, 10:45 pm
That's good to know. I know when I ran a air filter on my 460 it was a night and day differance. I don't want to run this engine without a air filter unless I'm at a drag strip.
Has anyone used the K&N filter assembly they sale for the Dominator's? (They only sale one)
jones
Post  kjett January 13th 2015, 9:02 am
Like I mentioned before, I use the Speedway Motors 4x14" re-usable filter ($24 vs. the K&N @ $62) and the Speedway Superflow top (again $30 vs. K&N @ $70). You can buy a nice spun aluminum base for a 4500 or make one and the whole deal will be less than the K&N stuff. I'm not into the "Pretty" aspect, but more for functionality being I race a mud truck. I also run the Outerwear cover to keep the big chunks out. Very Happy
kjett
kjett
