Parts cleaner?
+7
nuclearcobra
paulie9fingers
68fstbck
bosshoss
chuck
11 posters
Parts cleaner? Empty Parts cleaner?
Post  chuck January 18th 2010, 10:36 pm
What chemical are you'll using in your parst cleaner, mineral spirits a bad idea? Thanks!
chuck
Parts cleaner? Empty Re: Parts cleaner?
Post  bosshoss January 18th 2010, 10:43 pm
Good old Varsol.... but I am old and ornery.... Very Happy
dkp
bosshoss
bosshoss
Post  69F100 January 18th 2010, 10:47 pm
Mineral spririt work ok when I use it I mix 1 gal of lacquer tinner to 4 gal of mineral spririts seam to make it cut better but when not using it keep the lid closed
Jim
Post  bbf-falcon January 18th 2010, 11:19 pm
Brake cleaner Shocked I get it FREE
Post  68fstbck January 18th 2010, 11:24 pm
stodder solvent, almost like mineral spirts with some additives.I use a filter bag so it lasts awhile,costs almost $45. for 5gal. at larger parts suppliers.
68fstbck
Post  paulie9fingers January 19th 2010, 12:16 pm
I use mineral spirits to do the big dirty stuff and then do some final cleaning with K&W carburetor cleaner, the stuff is to expensive to use to do the whole job but it works great !
paulie9fingers
paulie9fingers
Post  nuclearcobra January 20th 2010, 8:40 am
I been using kerosene for years but was wondering if mineral spirits would be better and stink less ?
nuclearcobra
nuclearcobra
Post  chuck January 20th 2010, 11:57 pm
I think I'm going to try mineral spirites, what sucks is i need 30 gallons.
chuck
Post  res0rli9 January 21st 2010, 12:03 am
Varsol is what I used to use also, but cant find it down here???
could get it at gas stations in Va.
Post  paulie9fingers January 21st 2010, 8:39 am
I used to use Varsol too but can't get it around me anymore, that's why I switched over to the mineral spirits.
paulie9fingers
paulie9fingers
Post  DILLIGASDAVE January 21st 2010, 9:04 am
In the good old days we never used parts washers or (somewhat) EPA friendly solvents. We just cleaned parts with plain old gas or diesel in a drain pan, then dumped it out the back door of the shop when done. Helped kept the weeds in check. Laughing
The old guy in the shop next to me used to dump all his used motor oil out the back door of his shop for what seemed like 100 years. Everyone else in the row of shops had dirt/weeds out behind their shops. But this old guy had dumped so much used oil out back over the years that it was like he had poured asphalt out there. Shocked
Post  Broncoholic January 22nd 2010, 1:15 pm
chuck wrote:I think I'm going to try mineral spirites, what sucks is i need 30 gallons.
Call Saftey Kleen if there is on around, good old fashioned stuff. Do not get recycled...
Broncoholic
Broncoholic
Parts cleaner? Empty Mineral Spirits
Post  747JetMech January 22nd 2010, 8:02 pm
What I do is fill the part washer just below the pickup with water. Then I fill it the rest of the way with mineral spirits. Much cheaper!
747JetMech
747JetMech
